SCIO 37 when loading TP programs from RoboGuide
  • Hi there,
    I have 2 systems which have the same controller, but are different versions. 8.2 v 8.3.
    I made robot changes to the 8.3v and want to take the TP programs to the 8.2v as the system are the same in what they do.
    When I load the files, the system gives me this SCIO 37 "something invalid" and I do not know what is invalid.
    Any ideas for this? I used RoboGuide to boot up the 8.3v and saved the programs to a USB stick.
    I cannot at the moment get the 8.2v working as I need to get the frame work version correct.
    Best Regards,
    Lon :thumbs_up:
  • I figured it out. I guess in 8.2v, the IF THEN ELSE ENDIF is different and this is why it will not load.
    Colleague with 8.2v was able to see where the error occured and did a compare and found out what was the difference.
    Best Regards,
    Lon :thumbs_up:
