Linear unit - move only E1
  • litrmleka
  • August 9, 2022 at 8:47 PM
  • litrmleka
    26
    Hi.
    KRC4 8.3
    I have a question, how to set the E1 axis motion (linear unit along X axis) only in KRL. Without holding the tool TCP.
    Movements E1 (LIN, PTP) in the KRL keep the TCP (cartesian) in place.
    I need movement like in T1 and AXIS only and E1 is moved without holding the TCP.
    Now if i need move robot with tool I make something like this:
    LIN {X 1000, E1 1000}
    And I would like an E1 1000 and X tools to move together only with:
    MOVE {E1 1000}
    Regards.
  • Fubini
    270
    1,869
    • August 9, 2022 at 9:00 PM
    • Best Answer
    By default without stating something else {E1 1000} is interpreted as cartesian position. In cartesian moves coupling is on. If you command a axis position type only the external axis should move. So the trick is how to tell the system you want {E1 1000} interpreted as axis position. Various methods to achive this
    1) Declare a axis type variable and use it e.g.
    E6AXIS myAXIS
    myAXIS.E1 = 1000
    LIN myAXIS
    2) Use directly an axis type variable
    LIN {E6AXIS: E1 1000}
    Fubini
  • litrmleka
    26
    • August 10, 2022 at 8:58 AM
    Thank you Fubini. This is what I need. Regards.
Similar Threads
  • weave delay not working on slave robot while it following the external axis (linear unit)
    • Thunder
    • April 8, 2022 at 5:22 AM
    • KUKA Robot Forum
  • KR10 with Custom DKP - cannot couple correctly
    • rappelkiste
    • March 22, 2021 at 8:22 AM
    • KUKA Robot Forum
  • Error E6007
    • DChernyshev
    • September 23, 2020 at 7:12 PM
    • Kawasaki Robot Forum
  • Motors for robot arm
    • principemestizo
    • September 13, 2020 at 9:01 AM
    • General Robotics Discussions - everything but NO Industrial Robots
  • DX200 mpMotSetAccuracy for external axes
    • quarz
    • April 30, 2020 at 5:17 PM
    • Yaskawa Motoman Robot Forum
  • E1
  • linear
