"Busy popup window" via KRL
  • Nikolay Noskov
  • August 4, 2022 at 10:21 AM
  • Nikolay Noskov
    8
    Hi there!
    Are there any possibility to generate popup SmartHMI windows like a picture below from KRL? Maybe it's a kind of dialog window?
    KSS 8.5~8.6
    Thanks!
    Images
      • 41.39 kB
      • 602 × 394
      • 8
  • panic mode
    1,262
    13,027
    • August 4, 2022 at 3:14 PM
    not exactly, but you could get similar thing using dialog. note that dialog must have at least one button or it will not show up, and if button is clicked, dialog will go away. so you need to display it again as long as "busy" is in progress and remove it when not busy.
    SkyeFire
    1,038
    9,371
    • August 4, 2022 at 3:38 PM
    In KRL, the SET_KRLDLG function is passed the message text, an array of text values for each button, some parameters, and passes back an integer "handle" attached to the dialog box that SET_KRLDLG pops up.
    Normally, the pop-up only clears when one of the buttons is pressed, but it's also possible to clear the pop-up from inside your program using CLR_KRLMSG (Handle Variable).
    In "raw" KRL, something like:
    nDialogMsgHandle=SET_KRLDLG(_Msg, _MsgPar[], _MsgSoftKey[], FI_MsgOpt)
    WAIT FOR Clear_KrlMsg(nDialogMsgHandle)
    I've never tried creating a Dialog pop-up with no buttons, but you could give it a shot. If it doesn't work for some reason, you could simply create one button and put your program into a loop that keeps popping the pop-up back up until the program is satisfied.
    The MsgDialog subroutine in the MsgLib library (located in the SYSTEM directory of your robot) is a good example of Dialog, although it doesn't support clearing the pop-up programmatically.
    I once made a modified version of MsgDialog that would allow my program to clear pop-ups based on either a SmartPad button being pressed, or on a value being sent from the PLC -- the PLC HMI "echoed" the SmartPad application messages, so the robot had to accept responses from either source.
    DEF Dialog (FO_nAnswer:OUT,FI_chText[]:IN,FI_chModule[]:IN,FI_chTextPar[]:IN,FI_chDialogSK1[]:IN,FI_chDialogSK2[]:IN,FI_chDialogSK3[]:IN,FI_chDialogSK4[]:IN,FI_chDialogSK5[]:IN,FI_chDialogSK6[]:IN,FI_chDialogSK7[]:IN,FI_bNoBrakes:IN, FI_nMsgNr:IN,FI_MsgOpt:IN)
      ;FOLD HEADER
      ; Modified from stock MsgLib Dialog-message subroutine
      ; Adds capacity for both local and remote dialog response buttons
      ; Use O_ and I_ outputs and inputs that must be configured in the .DAT file of this module
      ;ENDFOLD (HEADER)
      ;FOLD DECLARATIONS
      DECL KrlMsg_T _Msg
      DECL KrlMsgPar_T _MsgPar[3]
      DECL KrlMsgOpt_T FI_MsgOpt
      DECL KrlMsgOpt_T _DummyMsgOpt
      DECL KrlMsgDlgSK_T _MsgSoftKey[7]
      DECL INT _nCount, _nLength, _nHandle, FO_nAnswer, FI_nMsgNr
      DECL BOOL FI_bNoBrakes
      DECL BOOL _bRet
      DECL CHAR FI_chText[], FI_chModule[], FI_chTextPar[], FI_chDialogSK1[], FI_chDialogSK2[], FI_chDialogSK3[], FI_chDialogSK4[], FI_chDialogSK5[], FI_chDialogSK6[], FI_chDialogSK7[]
      DECL CHAR _chMsg[255], _chMsgToPLC[300], _chConvertedMsg[255], _chTextPar[45]
      DECL BOOL _bReplyFromPLC
      DECL STATE_T _State
      DECL INT _nOffset
      DECL BOOL _bReplyFromSmartPad
      DECL BOOL _bMessageReceivedByPLC
      ;ENDFOLD (DECLARATIONS)
      ;FOLD EXECUTABLE
      O_MessageCode       = 0 ; clear output
      _bReplyFromPLC      = FALSE
      _bReplyFromSmartPad = FALSE
      FO_nAnswer          = 0
      ; check that there are no lingering PLC inputs
      WAIT FOR (I_OperatorButton == 0)
      ; Handle undefined Options variable
      ON_ERROR_PROCEED
      _DummyMsgOpt=FI_MsgOpt
      IF ($ERR.Number<>0) THEN
        FI_MsgOpt.VL_Stop=TRUE ;DEFAULT setting TRUE
        FI_MsgOpt.Clear_P_Reset=TRUE
        FI_MsgOpt.Log_To_DB=FALSE
        ERR_CLEAR($ERR)
      ELSE
        ERR_RAISE($ERR)
      ENDIF
      ;Creates default values in case of none availability
      FI_MsgOpt=CheckOfMsgOpt(FI_MsgOpt)
      _Msg.Nr=1
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _Msg.Nr=FI_nMsgNr
      _nLength=STRLEN(FI_chText[])
      IF  _nLength>0 THEN
        IF _nLength>80 THEN
          _nLength=80
        ENDIF
        FOR _nCount=1 TO _nLength
          _Msg.Msg_txt[_nCount]=FI_chText[_nCount]
          _chConvertedMsg[_nCount] = FI_chText[_nCount]
          ; Convert %1 to %s for SWrite to include text parameter in msg to HMI
          IF (_nCount > 1) THEN
            IF ((_chConvertedMsg[_nCount-1] == "%") AND (_chConvertedMsg[_nCount] == "1")) THEN
              _chConvertedMsg[_nCount] = "s"
            ENDIF
          ENDIF
        ENDFOR
        ; SWrite will fail if last character is %
        IF (_chConvertedMsg[_nCount-1] == "%") THEN
          _chConvertedMsg[_nCount-1] = " "
        ENDIF
      ELSE
        _Msg.Msg_txt[]="parameter FI_chText[] is missing"
      ENDIF
      _nLength=STRLEN(FI_chModule[])
      IF  _nLength>0 THEN
        IF _nLength>24 THEN
          _nLength=24
        ENDIF
          _Msg.Modul[_nCount]=FI_chModule[_nCount]
        ENDFOR
      ELSE
        _Msg.Modul[]="Appl"
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK1[])
      IF  $ERR.Number==0 THEN
        IF _nLength > 0 THEN
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[7].Sk_Type = #KEY
            _MsgSoftKey[7].Sk_txt[_nCount] = FI_chDialogSK1[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[7].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK2[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[6].Sk_Type = #KEY
            _MsgSoftKey[6].Sk_txt[_nCount] = FI_chDialogSK2[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[6].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK3[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[5].Sk_Type = #KEY
            _MsgSoftKey[5].Sk_txt[_nCount] = FI_chDialogSK3[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[5].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK4[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[4].Sk_Type = #KEY
            _MsgSoftKey[4].Sk_txt[_nCount] = FI_chDialogSK4[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[4].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK5[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[3].Sk_Type = #KEY
            _MsgSoftKey[3].Sk_txt[_nCount] = FI_chDialogSK5[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[3].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK6[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[2].Sk_Type = #KEY
            _MsgSoftKey[2].Sk_txt[_nCount] = FI_chDialogSK6[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[2].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      _nLength=STRLEN(FI_chDialogSK7[])
          IF _nLength>24 THEN
            _nLength=24
          ENDIF
          _MsgSoftKey[1].Sk_Type = #KEY
            _MsgSoftKey[1].Sk_txt[_nCount] = FI_chDialogSK7[_nCount]
          ENDFOR
        ENDIF
      ELSE
        FOR _nCount=1 TO 24
          _MsgSoftKey[1].Sk_txt[_nCount] = " "
        ENDFOR
      ENDIF
      _nLength=STRLEN(FI_chTextPar[])
      IF  _nLength>0 THEN
        IF _nLength>26 THEN
          _nLength=26
        ENDIF
          _MsgPar[1].Par_Txt[_nCount]=FI_chTextPar[_nCount]
          _chTextPar[_nCount] = FI_chTextPar[_nCount]
        ENDFOR
        _MsgPar[1].Par_type=#Value
      ENDIF
      ; Write text variable into Message
      _nOffset = 0
      SWRITE(_chMsgToPLC[], _State, _nOffset, _chConvertedMsg[], _chTextPar[])
      ; Steering logic
      bDialogToPLC = (($EXT OR $AUT) AND (NOT bPlcSim))
      bDialogToSmartPad = TRUE ; NOT $EXT
      ; bDialogToSmartPad = ((($EXT OR $AUT) AND NOT I_ClearToLeaveStandstill) OR $T1 OR $T2)
      ; Send dialog and buttons to PLC
      IF bDialogToPLC THEN
        WAIT FOR NOT (I_DialogReceived OR I_DialogResend)
        REPEAT
          ;UserDialogToPLC(_chMsgToPLC[], _Msg.Modul[],_MsgSoftKey[1].SK_TXT[],_MsgSoftKey[2].SK_TXT[],_MsgSoftKey[3].SK_TXT[],_MsgSoftKey[4].SK_TXT[],_MsgSoftKey[5].SK_TXT[],_MsgSoftKey[6].SK_TXT[],_MsgSoftKey[7].SK_TXT[],_Msg.Nr )
          O_MessageCode = nMessageCodeMemory ; transmit message code
          REPEAT
            PULSE(O_DialogSent, TRUE, 0.1)
          UNTIL(I_DialogReceived OR I_DialogResend)
          IF I_DialogResend THEN
            O_DialogSent = FALSE
            WAIT FOR NOT (I_DialogResend)
          ENDIF
        UNTIL I_DialogReceived
        WAIT FOR NOT (I_DialogReceived)
      ENDIF
      ;Send Dialog and Buttons to SmartPad
      IF bDialogToSmartPad THEN
      ELSE
        MsgState(nDialogMsgHandle, "Operator Dialog Message on Cell HMI", "Dialog")
      ENDIF
      ERR_CLEAR($ERR)
      ON_ERROR_PROCEED
      FI_bNoBrakes=FI_bNoBrakes
      IF  NOT($ERR.Number==0) THEN
        FI_bNoBrakes=FALSE
      ENDIF
      ; Wait for either SmartPad button or button code input via FieldBus
      REPEAT
        WAIT SEC 0.2
        _bReplyFromSmartPad = (bDialogToSmartPad AND NOT Exists_KrlDlg (nDialogMsgHandle, FO_nAnswer) AND (FO_nAnswer > 0))
        _bReplyFromPLC = (bDialogToPLC AND NOT (I_OperatorButton == 0))
        IF _bReplyFromPLC THEN
          SWITCH UserButton (I_OperatorButton)
          CASE #Invalid
          DEFAULT
            ; leave _bReplyFromPLC alone
          ENDSWITCH
        ENDIF
      UNTIL (_bReplyFromPLC or _bReplyFromSmartPad)
      ; Reply recieved from PLC
        ; If loop exited due to remote PLC input
        FO_nAnswer    = I_OperatorButton
        O_MessageCode = 0 ; clear Message output
        WAIT FOR (I_OperatorButton == 0) ; wait for PLC acknowledgement
        ;MsgNotify("Reply From PLC %1", "Dialog", FO_nAnswer)
        WAIT SEC 1.0 ; Debounce
        ; Clear SmartPad message
      ELSE
        ; Reply received from SmartPad
        IF _bReplyFromSmartPad THEN
          ; Loop was exited due to SmartPad button
          ; FO_nAnswer was set by Exists_KrlDlg()
          ; MsgNotify("Reply From SmartPad %1", "Dialog", FO_nAnswer)
        ENDIF
      ENDIF
      IF FI_bNoBrakes THEN
        PTP $AXIS_ACT
      ENDIF
      ;ENDFOLD (EXECUTABLE)
    END
  • panic mode
    1,262
    13,027
    • August 4, 2022 at 3:43 PM
    does it need to be a popup? status message would be perfect for this
  • Nikolay Noskov
    8
    • August 5, 2022 at 8:43 AM
    Panic mode, SkyeFire, thank a lot for quick answer. I've understood that have no easy way to generate the popup window.
    Quote from SkyeFire
    Yes, i know how the SET_KRLDG function works. And my first think was about it. Thank you for good example i will investigate that!
    Quote from panic mode
    Yes it need to be a popup. I want to block any activity from User-s during my function is executed.
    Edited once, last by Nikolay Noskov (August 5, 2022 at 5:59 PM).
  • panic mode
    1,262
    13,027
    • August 7, 2022 at 7:33 PM
    Quote from Nikolay Noskov
    attempting to block "any activity" is going to be difficult. you may have to define what the "any activity" really is. popup does not prevent user from using (or letting go) of enabling switch, turning mode switch or pressing anything that is not on screen. creating and removing custom popup is not really a big deal, it is just that it would need a bit more than just KRL if it need to look certain way (without button). the bigger question what is it that you are trying to prevent.
  • Smarthmi
  • Busy popup
