  4. Stäubli & Bosch Robot Forum
How to resolve "ERR 123-Not linked to a hardware input output"
  • Rahul Sajeev
  • July 25, 2022 at 2:33 PM
  • Rahul Sajeev
    I'm writing a VAL3 program for starting a filling process through HMI of our PLC and not with the teach pendent. I created an IO board and created a 32bit DIGITAL input and output and allocated the inputs and outputs using "diolink" . WHen i try to run the program on VAL3 it shows this error "ERR 123-Not linked to a hardware input output". I have used the same dio before in another code and it was working but now it's still showing this error however i try to change it. Can you tell me how this error can be resolved?
  • SD-Matic
    8
    • August 2, 2022 at 3:34 PM
    If I check the SRS documentation, you must use diolink with signals that are already connected to physical IO :
    (Sorry, in french) :
    void dioLink(dio& diVariable, dio diSource)
    Fonction
    Cette instruction lie diVariable à l'entrée/sortie à laquelle diSource est lié.
    Exemples
    Cette application utilise un signal qui peut être configuré à l'aide de différents matériels. Le programme ci-dessous détermine quel matériel est installé afin d'initialiser la variable diSignal qui est utilisée ensuite dans le reste de l'application.
    If I understand, diolink is not used to link a dio signal to a physical link, but only to link dio signals between themselves.
  • ElEsgalho
    17
    119
    • August 3, 2022 at 5:23 PM
    Yes, relink it again for the new controller... Sometimes the physical address changes from controller to controller.
  • Galet
    19
    141
    • August 11, 2022 at 1:53 PM
    Is you application running on CS8 or CS9 controler ?
    You IO are connected to an physical board or on Fieldbus board ?
  • VAL3
  • Staeubli
  • cs9
