Hello guys,need help with robinstall, I created a system but when I try to make boot disk it showes me anerror -2111 Failed to create target file.does anyone know why?
Do you also have the version of robotware installed that the system requires?
If you have newer, you can modify the system to upgrade, but you cannot downgrade.
you still don't tell what sistem you have ,
do you have the Boot?
the sistem can be downloaded with robinstall ,with network cable (its not necesary to create Floppy
we need to Know What Type Of RobotWare you have,
My Personal Advice Keep the Original version Do not Upgrade or Downgrade
if you don't have the boot Its the Mother Board broken or HardDisk.
give more information
What Hapend wit Computer when Start, What write on Screen?
Hallo Black, it is M2000 S4C+, we have changed the main computer, we do connect with robinstall but it can not download the system, it gives an error saying "can not create file directory" so we try with the boot disc. We are using the existing system keys.
You have this screen when comp start?
Test conection it's work?
The IP 192.168.125.82
Mask. 255.255.255.240
Gateway 192.168.125.81
yes, Black , we have that screen but Robinstat does not finish downloading the system. Then we try with boot discs. The problem now is that after finishing loading all the boot discs, when we go to select system no system appears.
Hello i want to share my solution i have a usb floppy emulator on S4C+ controller if you have one on your controller you can download ketron usb format tool to make usb as a floppy and than you can make a backup or boot your controller with that usb !
If you need help just pm to me
Best Regards
Did you solve the problem
