  4. ABB Robot Forum
Timer
  • Mangesh Shenavi
  • July 15, 2022 at 12:19 PM
  • Mangesh Shenavi
    80
    Hello.
    I am new to ABB.
    I want to use timer in ABB robot, but i didn't found, where is it.
    I want to use them as like kuka robot i.e. explaied below:
    First i declared an integration
    DECL INT TIMER=1 , in conf.
    Then i creat a program as below
    SWITCH TIMER
    CASE 1
    $TIMER_STOP[2]=TRUE
    $TIME[1]=0
    $TIMER_STOP[1]=FALSE
    TIMER=2
    CASE 2
    $TIMER_STOP[1]=TRUE
    $TIMER[2]=0
    $TIMER_STOP[2]=FALSE
    TIMER=1
    ENDSWITCH
    As like this, i want to add in ABB robot, Please help🙏
    My ABB robot model is IRB 6700-200/2.60 :smiling_face:
  • Roland Keller
    5
    61
    • July 15, 2022 at 1:33 PM
    Check the Robotstudio help. Keyword Clk. This could be your friend.
  • JMF
    55
    • July 15, 2022 at 2:30 PM
    VAR num nClock;
    VAR clock cClock;
    PROC BlahBlah()
    ClkReset cClock;
    ClkStart cClock;
    ! Procedure instructions
    ClkStop cClock;
    nClock:=ClkRead(cClock\HighRes);
    TPPrint "BlahBlah Procedure took: "+NumToStr((nClock/60),3)+"minutes";
    nClock:=0;
    ENDPROC
  • Mangesh Shenavi
    80
    • July 15, 2022 at 3:15 PM
    This logic slightly looks critical,
    Can you please share that
    1) How to start timer
    2) How to stop timer
    3) How to reset timer
    4) Where i can check my counted time.
    Please
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • July 15, 2022 at 3:20 PM
    It is all right there in black and white. You need to read the Instructions, functions and datatypes manual.
  • Mangesh Shenavi
    80
    • August 4, 2022 at 10:30 AM
    Quote from JMF
    VAR num nClock;
    VAR clock cClock;
    PROC BlahBlah()
    ClkReset cClock;
    ClkStart cClock;
    ClkStop cClock;
    nClock:=0;
    ENDPROC
    I got start clock, stop clock & reset clock option. Thank you for it.
    But where can i check my calculated time ??
  • robotecnik
    19
    568
    • August 4, 2022 at 11:41 AM
    In KUKA (the code you've posted) you have an array of timers (which is a horrible implementation as you have a specific amount of timers available).
    In ABB they offer you several functions to start a timer.
    The example posted by JMF is perfect, concise, and detailed.
    Just to make it easier for you to understand the "translation":
    ClkReset ! == TIMER[x] = 0
    ClkStart ! == TIMER_STOP = FALSE
    ClkStop !== TIMER_STOP = TRUE
    ClkRead !== variable = TIMER[x]
    BUT: ABB has one of the best documentations out there, check the manual Lemster recommended you and you'll see samples and instructions on how to make all those functions work:
    ClkReset, ClkStart, ClkStop and ClkRead
    Hope this helps.
    http://www.robotecnik.com | Robots, CNC and PLC programming.
  • Mangesh Shenavi
    80
    • August 4, 2022 at 6:24 PM
    Thank you so much JoanM.
    I could understand better because of your brief explanation.
Similar Threads
  • associate a timer to action
    • hugochab38
    • November 27, 2018 at 2:10 PM
    • KUKA Robot Forum
  • Timer in kuka
    • capital9
    • June 9, 2022 at 2:33 PM
    • KUKA Robot Forum
  • Issues reading a writing positions to text file for homing
    • emerald_geni
    • June 2, 2022 at 3:51 AM
    • KUKA Robot Forum
  • EKI - PTP commands executing too slow
    • Ravnicas
    • January 10, 2022 at 10:46 AM
    • KUKA Robot Forum
  • Controlling external machine and robot at same time from KRL
    • wassimj
    • June 15, 2021 at 8:41 AM
    • KUKA Robot Forum
  • KRL code to save robot Positions timestamped in a text file. (KRC4)
    • kiiwa
    • May 11, 2017 at 6:16 PM
    • KUKA Robot Forum
  • Weld controller communication
    • arun_AR
    • June 28, 2020 at 5:16 PM
    • Kawasaki Robot Forum
  • How should I time events in loops?
    • jacks319
    • December 28, 2015 at 5:57 PM
    • KUKA Robot Forum
  • fanuc robot timer cycle %
    • Budwin2106
    • July 12, 2018 at 4:08 PM
    • Fanuc Robot Forum
  • TIMER not start
    • MUNIACO
    • June 14, 2018 at 9:20 PM
    • Fanuc Robot Forum
