Is this Possible to Control Vaccum head which is attached to Fanuc robot without PMC Program??
Fanuc Robot
Sab_1994 -
July 14, 2022 at 3:43 PM -
You mean a vacuum gripper? You don't need PMC to control your tool.
Yes 7 Suction Cups are having in a gripper. For this 2 Solinoids are using to control the ON and OFF. for this we need Separate PMC for this or can Control it in another way??Give your Suggestions..
You can do it using robot ins and outs which are in EE connector (8 ins + 8 outs but the maximum ins and outs also depends of your robot type).
You don't need PMC. Or do you mean a PLC? For a specific answer we need more details, at least which robot model and controller type, do you have a fieldbus running and how can the gripper be connected (discrete IOs, fieldbus, etc.)?
There are many options, e.g. using external or internal valves (depending on the robot model. But personally I don't recommend using these for vacuum applications), discrete IOs or via fieldbus, etc.
Please provide more information to get an answer to your question.
DS186, Thank you for your Reply.. I will Provide the Details after Design finalized..
Could explain how to do IO assignments in Fanuc Robots as Mentioned in Image.
Rack 102 is for Molex Dual Channel PROFINET Device. Search for "rack numbers" and you will find a lot of information here in the forum.
Hi
Look for rack numbering system here
ThreadSettings to make Fanuc programming easier (From all of us)
Hello all
I wanted to do this for a long time. A compilation of information that generally takes hours to find on manuals (if you can find them)
This is a contribution from of all us
I will collect the info from posts that I find beneficial (You can PM to help me)
I'm going to try to keep clean, just info, no comments, no thanks , just pure info
It will be and sticky and it will be locked.
On my first day collecting information I realized that's almost impossible to do it without modifying the…Fabian MunozFebruary 5, 2017 at 5:50 PM Example
do[1- 80] 102 1 1
means you are assigning the outputs 1 to 80 to rack 102 starting at 1
Slot 1 will be like a motherboard where you connect the different devices
Thank You so much for your brief Explanation. I Understood.
