I had my pallet 6 inches off in the wroing direction in Handling tool and now when boxes drop on real pallet they are all 6 inches too far forward. Is there anyway to program this so I don't have to touch up every single point?
How make all drops +X 6 inches without having to do each one by one?
cat91345 -
July 13, 2022 at 8:56 PM -
If you're using userframes, just adjust the frame. If not, use the program adjust utility (menu>utilities>Prog Adjust) to edit the relevant points.
Or a bit longer way - add an offset to every point.
You can also edit the points manually by adding/subtracting 152.4mm (25.4*6) if the error is inline with an axis.
