In the following image is the ladder block I'm using to start a robot in EXT mode from a siemens PLC. This block was made based on the signal diagrams on the KSS manuals but it seems to not work sometimes. 95% of the time when this block is run the robot starts correctly but sometimes it doesn't respond, as if the start sequence wasn't received.
Just to clarify, "RobotControl" in this example is a structure to write commands and the status of the robot.
I was wondering if any of you could share how you do it or at least any comments or opinions.
Thank you.
