PCDK Read numeric register in C#
  • AxelZ
  • July 8, 2022 at 9:41 AM
  • AxelZ
    Hello all,
    I am trying to read the numeric registers of a robot via C#. The whole thing works as long as it is an integer. As soon as the register contains a floating point number an exception is thrown.
    Code excerpt:
    var numRegister = (myRobot.RegNumerics[1].Value.RegLong);
    If register 1 is an integer (e.g. 100) it works. If not then the following message appears: System.Runtime.InteropServices.COMException: "Register value is not of Integer type.
    Makes sense because the value is not an integer. Now my question.
    Does anyone know how I can read floating point numbers ? Or is that not possible ?
    Kind regards
  • Erik Olsen
    62
    5
    197
    • July 9, 2022 at 5:55 PM
    • Best Answer
    Unless I'm reading it wrong, I think it's because you are getting the register value using the "RegLong Property". Long data type is for integers only.
    The Fanuc PCDK documentation has a description for the property stating this:
    Quote
    FRCRegNumeric.RegLong Property
    Description:
    Returns/sets the long value for the numeric register.
    Syntax:
    [lngRegInt = ] objNumReg.RegLong
    Parts:
    objNumReg as FRCRegNumeric lngRegInt as Long
    Remarks:
    This property will raise an error if it is read when the type is not INTEGER (Type property is not frIntegerType). When this property is set the register type is automatically converted to INTEGER (Type property is set to frIntegerType).
    To get the floating-point value of a numeric register, you will want to use the standard RegNumerics Property here:
    Quote
    FRCRobot.RegNumerics Property
    Description:
    Returns the robot numeric registers.
    Syntax:
    [objNumRegs = ]objRobot.RegNumerics
    Parts:
    objRobot as FRCRobot objNumRegs as FRCVars
    Remarks:
    This property provides access to the numeric registers of the controller. These registers are typically accessed from TP programs.
    See Also:
    FRCRobot Object Overview FRCVars Object Overview FRCVar Object Overview FRCRegNumeric Object Overview
    Example of getting the numeric registers
    Dim objRobot as FRCRobot
    Dim objNumRegs as FRCVars
    Dim objNumReg as FRCVar
    Dim objRegValue as FRCRegNumeric
    Dim lngValue as Long
    Set objRobot = New FRCRobot objRobot.Connect "robot1"
    Set objNumRegs = objRobot.RegNumerics
    Set objNumReg = objNumRegs(1)
    Set objRegValue = objNumReg.Value
    lngValue = objRegValue.RegLong
    `Example of getting the numeric registers Dim objRobot as FRCRobot Dim objNumRegs as FRCVars Dim objNumReg as FRCVar Dim objRegValue as FRCRegNumeric Dim lngValue as Long Set objRobot = New FRCRobot objRobot.Connect "robot1" Set objNumRegs = objRobot.RegNumerics Set objNumReg = objNumRegs(1) Set objRegValue = objNumReg.Value lngValue = objRegValue.RegLong
    All of this and more is available in the PCDK documentation that came with the dev kit download btw :winking_face: .
  • AxelZ
    • July 13, 2022 at 9:05 AM
    Hey Erik, thanks for the help. The solution is quite simple :face_with_tongue:
    var numRegister = myRobot.RegNumerics[1].Value.RegLong; --> returns the long value
    var numRegister = myRobot.RegNumerics[1].Value.RegFloat; --> returns the float value
    Thank you.
  • HawkME
    570
    3,270
    • July 13, 2022 at 1:54 PM
    Registers can dynamically change from long to float based on usage. I would recommend putting it in a try/catch block and it fails then test for the other type.
  • AxelZ
    • July 13, 2022 at 2:29 PM
    Hey HawkME,
    thanks for the advice. I did excaly what you mentioned because i got that error. First i try to get the integer Value of a Register and if its not possible have a catch where i get the float value.
    Cheers
  • rankingofficer
    8
    • September 20, 2022 at 9:17 AM
    Use this: objRegValue.Type = FRETypeCodeConstants.frIntegerType
    If objRegValue.Type = FRETypeCodeConstants.frIntegerType Then
    numberList.Add(objRegValue.RegLong)
    Else
    numberList.Add(objRegValue.RegFloat)
    End If
  • superbei30
    50
    • January 8, 2023 at 11:01 PM
    Hi everyone,
    Does anyone know the syntax of c# code reading and writing values from and to the IOs?
    Thank you.
  • Alfred
    8
    34
    • July 2, 2025 at 1:55 PM
    • New
    This alternative to PCDK, called UnderAutomation.Fanuc (100% managed in .NET, no COM, no ActiveX, less expensive, site license: pay once and use forever regardless of the number of developers, software, or robots) allows you to read and write registers using the native SNPX protocol:
    Github : https://github.com/underautomation/Fanuc.NET
    Example :
    C#
    using UnderAutomation.Fanuc;
    // Create a new Fanuc robot instance
    FanucRobot robot = new FanucRobot();
    // Set connection parameters
    ConnectionParameters parameters = new ConnectionParameters("192.168.0.1");
    parameters.Snpx.Enable = true;
    // Connect to the robot
    robot.Connect(parameters);
    // Read a register
    Position posReg1 = robot.Snpx.PositionRegisters.Read(1);
    float numReg5 = robot.Snpx.NumericRegisters.Read(5);
    string strReg10 = robot.Snpx.StringRegisters.Read(10);
    // Write a register
    posReg1.CartesianPosition.X = 100;
    robot.Snpx.PositionRegisters.Write(1, posReg1);
    robot.Snpx.NumericRegisters.Write(2, 123.45f);
    robot.Snpx.StringRegisters.Write(3, "Hello, world!");
    // Read a variable
    int rmtMaster = robot.Snpx.IntegerSystemVariables.Read("$RMT_MASTER");
    string lastAlm = robot.Snpx.StringSystemVariables.Read("$ALM_IF.$LAST_ALM");
    Position cellFloor = robot.Snpx.PositionSystemVariables.Read("$CELL_FLOOR");
    // Write a system variable
    robot.Snpx.IntegerSystemVariables.Write("$RMT_MASTER", 1);
    robot.Snpx.StringSystemVariables.Write("$ALM_IF.$LAST_ALM", "No alarms");
    robot.Snpx.PositionSystemVariables.Write("$CELL_FLOOR", cellFloor);
    // Write a Karel program variable
    robot.Snpx.IntegerSystemVariables.Write("$[KarelProgram]KarelVariable", 1);
    // Read and Write I/O (SDI,SDO,RDI,RDO,UI,UO,SI,SO,WI,WO,WSI,PMC_K,PMC_R)
    robot.Snpx.RDO.Write(1, true);
    ushort ai5 = robot.Snpx.AI.Read(5);
    // Read and Write analogs (AI,AO,GI,GO,PMC_D)
    robot.Snpx.AO.Write(2, 5);
    ushort ao3 = robot.Snpx.AO.Read(3);
Similar Threads
  • PCDK, Linux, .NET Core, and RoboGuide
    • SkyeFire
    • January 11, 2018 at 2:43 PM
    • Fanuc Robot Forum
  • Read and change register value from c# app using pcdk.
    • Limburger
    • April 9, 2019 at 6:37 PM
    • Fanuc Robot Forum
  • PDCK C#
