AX20 PLC I/O
  • Hi!
    I've been getting the hang of programming a AX20 nachi controller with a lot of success, but i cant seem to get the Internal PLC to read the physical standar input inside the controller.
    I used the standard i/o inputs inside the controller till now with the plc disconnect without a problem, but cant seem to get it work with the PLC reading it.
    A documentation about the plc programming would help me a lot but even a small example would be good to just have it work.
  • In Constant->Signal->Hardware setting, Make setting for Input- PLC Through
    I've tried to tick the box for the Standard I/O group to be used through the PLC but after that it asks me to power cycle the controller and the setting is not changed after restart.
