RV 2AJ
  • Hi all,
    I would like some help on controlling a RV-2AJ robot arm via PC using RS 232.
    I am able to send commands from a Linux terminal such as:
    echo -e -n '1;1;CNTLON\r' > /dev/ttyUSB0
    echo -e -n '1;1;SRVON\r' > /dev/ttyUSB0
    echo -e -n '1;1;PPOSF\r' > /dev/ttyUSB0
    and receive responses such as:
    QoK
    QoK
    QoKX;370.20;Y;0.98;Z;359.63;A;3.73;B;91.93;;6,0;100;0.00;00000000
    But, for commands
    echo -e -n '1;1;EXECPCOSIROP = (0,0,0,0,90,0) (6,0)\r' > /dev/ttyUSB0
    echo -e -n '1;1;EXECMVS PCOSIROP\r' > /dev/ttyUSB0
    the responses are
    QeR510000000
    QeR510000000
    I am not sure how to proceed.
    Do I have to create a program on the controller and THEN the PC can interact ?
    there doesn't seems to be documentation for EXECPCOSIROP.
    How do I command the arm to move in x,y,z using WHAT commands?
    Any help is greatly appreciated !
    thanks and regards,
    Mike.
  • never used that robot but I would start with check if the robot is even able to move (are the drives on and safety ok?)
  • Hi Panic mode.
    Yes, the drives and the robot works.
    I did a calibration and I can JOG the robot in JOINT, XYZ space from the Teach Pendant (T/B).
    It does respond to external inputs from the PC but is unable to perform the commands
    the responses are
    QeR510000000
    QeR510000000
    I had also set the Key on the T/B to Disable and the Key on the CR 571 controller to AUTO(EXT).
    regards,
    Mike
