Input signal problem
  • Hallo
    I am new in Mitsubishi Robot programming. I have a question. May be you guys can help me or advice. Is it possible to make an array for input signal. The idea is ,the robot will use simple light sensor and it will collect this signal in an array. So it can work with this signal later. Is it possible with mitsubishi robot programming language(Melfa basic vi).
  • hi
    Can you tell me how I can use this: (Character string type variable ARRAY)
    Dim CMOJI(7) ' Define the character-string type variable CMOJI having the seven elements.
    Could you please tell me, for an example
    CMOJI(1)= abc --> is possible to write
    Or how to write this array element.
