Hi, I am a new Motosim User,
I am unable to import any solidworks files into motosim except for step files (can't detect the edges for welding) , it says " files type not supported". I am using Solidworks 2022, is there a way to solve the issue?
What version of MotoSim EG-VRC are you using? Your EG-VRC version might not be new enough to support Solidworks 2022.
when you import the models you need to select that it is for CAM. Otherwise you won't be able to use CAM function.
From this table I understand that cant use for cam, from hsf downward.
I've used solidworks models for cam.
I am using Motosim 2020
And there we get to the table that Reintz posted, where you can see that just solid works 2003 to 2019 can be used, he was absolutely right.
Just now I've seen that you wrote that have used solid works 2022. 🤦♂️🤦♂️🤦♂️
