Flange force Sensor
  • Hi,
    The company im working in has a Yaskawa MH50-II robot (50kg payload) with a dx200 controller. They want me to use this robot to polish a metal product. Does this robot have, on the flange, a force sensor so i could program it to polish always at a certain force, that way when the brush starts to worn out it automatically compensates and increments forward.
    Best regards,
    Bruno Nogueira
  • Does the robot have by default a usable force sensor for this? No. Can one be added, yes. We commonly use a PushCorp active force sensor with the deburring equipment mounted to it.
    Yea that was what i thought, thank you!
    Regarding the polishing job, is it possible to rotate de flange of the robot without using a MOV fuction. It would kinda work like a motor, but only rotating 360º and back. If this is possible i could rotate the flange and move the robot in a linear path to polish a part
  • In a round about way. The job still has moves in it. Check out the manuals for T-axis speed control and Endless T. Doesn’t matter what generation the manual is from, the function has been basically the same since MRC.
    The part is a cylinder and i want to polish the wall of that said part. So basically i just want to rotate the T-axis but in order for me to do this is create to points with different T angles? Isnt Endless T a paid option? And is the manual the operator manual?
  • Both Endless T—axis and T-axis Speed Control are software options.
    They have their own separate manuals.
    By the way, is there anyway to change collision sensor sensitivity on teach mode? Because i wanto to test the program before actually run it on automatic but it might detect collision with the brush.
    • Helpful
    Shock Sens Level Condition Number 9 is for teach, you only have the 1 file.
