dialog message.
  • capital9
  • June 8, 2022 at 12:03 PM
  • capital9
    71
    hey guys,
    i am working with KRC4, KSS 8.6.8
    yesterday i went through robot forum looking for generating a dialog message and found this code would do the work.
    MsgDialog(,"Do you want to quit program?",,,"No","Yes")
    so when i run the program i get this message 'do you want to quit program' and option are YES /// NO .
    if i press yes the program continues and ends the program as i have programmed. so i have no problem with yes option
    but pressing no would also lead me to same result, how can i make a condition so that when NO is pressed it does something else.
    for example:
    if end_pallet_signal==true then ; end button pressed then it continues
    MsgDialog(,"Do you want to quit program? ",,,"No","Yes") ; dialog box appears option yes or no
    $out[900]=false ; if yes it continues
    goto start_of_program
    endif
    for above program i want to make it so that when No is pressed then $out[900]= false and goto some where else.
    i went through the manual but coulnot follow the example.
    help would be appreciated. thanks in advance.
    Edited once, last by capital9 (June 8, 2022 at 2:22 PM).
  • capital9
    71
    • June 8, 2022 at 2:18 PM
    msg = {modul[] "MyTech", Nr 7, msg_txt[] "Do you want to quit? "}
    SK[1] = {sk_Type #value, sk_txt[] "yes"}
    SK[2] = {sk_Type #value, sk_txt[] "no"}
    nHandle = Set_KrlDlg(msg, par[], SK[], opt)
        IF (nHandle > 0) THEN
          while (Exists_KrlDlg(nHandle, keynumber))
              wait Sec 0.1
          endwhile
          switch keynumber
              case 1
              case 2
    end_pallet_signal=false
                   goto continue_prog
          endswitch
        ENDIF
    endif
    Above code works for me fine. tried several time to make it work.
    i just follwed the kuka manual and thats it, but i still dont understand is how is that keynumber related to options (yes or no)
  • panic mode
    1,263
    13,030
    • June 8, 2022 at 4:03 PM
    DECL INT n, button
    FOR n=1 to 10
      MsgDialog(button, "Select option"," PANIC MODE","Lift","Kick","Push","Punch","Cut","Drop","Toss","Twist")
      MsgNotify("You pressed button %1","RESULT",button)
      WAIT SEC 1
    ENDFOR
  • panic mode
    1,263
    13,030
    • June 8, 2022 at 4:10 PM
    DECL INT button
    SWITCH button
      Case 1 ; Twist
        $OUT[900]=TRUE
      Case 2 ; Toss
        $OUT[900]=FALSE
      Case 3 ; Drop
        $OUT[901]=TRUE
      Case 4 ; Cut
        $OUT[900]=FALSE
      Default ; whatever...
        MsgNotify("Something else...")
    ENDSWITCH
Similar Threads
  • KUKA Message handling
    • xSubyx
    • May 23, 2022 at 12:50 PM
    • KUKA Robot Forum
  • KRC2 read number from KCP
    • Milan
    • March 23, 2022 at 9:50 PM
    • KUKA Robot Forum
  • How to create an information box with options to select in KRC2
    • sanoopgr8
    • November 9, 2014 at 4:05 PM
    • KUKA Robot Forum
  • Algorithm for Recording Unspecified Number of Points KRC2
    • EngineerTex
    • April 7, 2021 at 12:36 AM
    • KUKA Robot Forum
  • Variable input in dialog message KRC4.
    • luckey
    • December 4, 2020 at 9:46 AM
    • KUKA Robot Forum
  • Weekday variable?
    • Casper Vinding Olesen
    • May 26, 2020 at 10:44 AM
    • KUKA Robot Forum
  • Best practice : Dialog msg vs #Waiting msg
    • lionpeloux
    • November 14, 2018 at 10:53 AM
    • KUKA Robot Forum
  • SPS and DIALOG windows
    • Tiziano!
    • September 12, 2018 at 7:45 PM
    • KUKA Robot Forum
  • message
  • kuka programming
  • pop up
  • dialog
