Hi all,
I've inherited a robotstudio cell.
The guy who sent it to me attached the 3D clamp to the robot for me.
This said, yesterday I went to my customer and I've noticed the robot was moving in a very strange way... the tool was wrong mounted into the robot (rotated 60º).
SIMULATION PART
This morning, back in the office, and in robotStudio, I detached the tool from the robot.
Exported it to a 3D part, imported the 3D part again, moved that 3D part to 0,0,0 and rotated it 60º.
Created 2 frames (one for each tcp (it's a double clamp).
Created a tool using those frames.
Attached the clamp to the robot again.
Executed the simulation paths and the robot (with the rotated tool) moved along the path perfectly fine.
That part worked well...
SYNCHRONIZATION PART
After all this, I deleted all the related data from the old rapid programs, calib data (tooldata stored there) and Module 1 (simulation paths stored there).
And synchronized the simulation to RAPID to regenerate all the paths and tools.
If I execute the paths in the rapid program while seeing the graphical window, it shows the robot moving across the paths, but with the clamp rotated as it was before.
Which should not happen.
Am I missing any step? Have you noticed this before? Do you know how could I solve this?
Thank you in advance.
