Hello everyone,
I am facing an issue with KUKA Ethernet KRL. Basically what i want to do is to communicate with a UDP Server on the KRC and access it from a virtual machine, hosted on a Windows PC.
What happens is, that the robot rejects client connections to the UDP server.
The robot code building up the interface looks like this:
def eki_hw_iface_init()
decl eki_status eki_ret
global interrupt decl 15 when $flag[1]==false do eki_hw_iface_reset()
interrupt on 15
global interrupt decl 16 when $timer_flag[1]==true do eki_hw_iface_send()
interrupt on 16
wait sec 0.012
$timer[1] = -200
$timer_stop[1] = false
; Create and open EKI interface
eki_ret = eki_init("EkiHwInterface")
eki_ret = eki_open("EkiHwInterface")
end
The corresponding xml config file ("EkiHwInterface.xml"), stored to C:\KRC\ROBOTER\Config\User\Common\EthernetKRL is:
<ETHERNETKRL>
<CONFIGURATION>
<EXTERNAL>
<TYPE>Client</TYPE> <!-- Users connect as clients -->
</EXTERNAL>
<INTERNAL>
<ENVIRONMENT>Program</ENVIRONMENT> <!-- Server run via robot interpreter -->
<BUFFERING Limit="512" /> <!-- Allow buffering of up to 512 messages (system max) -->
<ALIVE Set_Flag="1" /> <!-- Use $flag[1] to indicate alive/good connection status -->
<IP>10.24.23.17</IP> <!-- IP address for EKI interface on robot controller (KRC) -->
<PORT>54600</PORT> <!-- Port of EKI interface on robot controller (in [54600, 54615]) -->
<PROTOCOL>UDP</PROTOCOL> <!-- Use UDP protocol -->
</INTERNAL>
</CONFIGURATION>
<!-- Configured XML structure for data reception (external client to robot)
<RobotCommand>
<Pos A1="..." A2="..." A3="..." A4="..." A5="..." A6="...">
</Pos>
</RobotCommand>
<RECEIVE>
<XML>
<!-- Joint position command -->
<ELEMENT Tag="RobotCommand/Pos/@A1" Type="REAL" />
<ELEMENT Tag="RobotCommand/Pos/@A2" Type="REAL" />
<ELEMENT Tag="RobotCommand/Pos/@A3" Type="REAL" />
<ELEMENT Tag="RobotCommand/Pos/@A4" Type="REAL" />
<ELEMENT Tag="RobotCommand/Pos/@A5" Type="REAL" />
<ELEMENT Tag="RobotCommand/Pos/@A6" Type="REAL" />
</XML>
</RECEIVE>
<!-- Configured XML structure for data transmission (robot to external client)
<RobotState>
</Pos>
<Vel A1="..." A2="..." A3="..." A4="..." A5="..." A6="...">
</Vel>
<Eff A1="..." A2="..." A3="..." A4="..." A5="..." A6="...">
</Eff>
</RobotState>
<SEND>
<XML>
<!-- Joint state positions -->
<ELEMENT Tag="RobotState/Pos/@A1"/>
<ELEMENT Tag="RobotState/Pos/@A2"/>
<ELEMENT Tag="RobotState/Pos/@A3"/>
<ELEMENT Tag="RobotState/Pos/@A4"/>
<ELEMENT Tag="RobotState/Pos/@A5"/>
<ELEMENT Tag="RobotState/Pos/@A6"/>
<!-- Joint state velocities -->
<ELEMENT Tag="RobotState/Vel/@A1"/>
<ELEMENT Tag="RobotState/Vel/@A2"/>
<ELEMENT Tag="RobotState/Vel/@A3"/>
<ELEMENT Tag="RobotState/Vel/@A4"/>
<ELEMENT Tag="RobotState/Vel/@A5"/>
<ELEMENT Tag="RobotState/Vel/@A6"/>
<!-- Joint state efforts (torques) -->
<ELEMENT Tag="RobotState/Eff/@A1"/>
<ELEMENT Tag="RobotState/Eff/@A2"/>
<ELEMENT Tag="RobotState/Eff/@A3"/>
<ELEMENT Tag="RobotState/Eff/@A4"/>
<ELEMENT Tag="RobotState/Eff/@A5"/>
<ELEMENT Tag="RobotState/Eff/@A6"/>
<!-- Interface state -->
<ELEMENT Tag="RobotState/RobotCommand/@Size"/> <!-- Number of elements currently in command buffer -->
</XML>
</SEND>
</ETHERNETKRL>
Regarding my fault detection so far:
When I examine the behaviour by Wireshark, I get the following impression: The Robot (IP 10.24.23.17) responds to the host PC (10.24.23.100) by "Destination unreachable (Port unreachable)". Attached you can find the screenshot.
My hypothesis:
I think there might be some issues in the network config. The xml file seems OK for me. Either there might be some kind of restriction on side of KUKA or on side of Windows. I have checked the Windows firewall settings and so far they did not look suspicious to me.
Is there any approach you guys recommend me? Or is there something I have not respected?
Thank you so much in advance.
System Specification:
KRC4 SC5
KSS V8.3.12
Windows 10 host PC
Oracle VM Virtual Box running Ubuntu FocalFossa
