Attached are images of what I've programmed.
Specifically, I'm at a loss of what's going on with lines 19 and 20 with the red 3 values.
19: PR[GP1:13,3]=PR[13,3]+4
20: PR[GP1:14,3]=PR[14,3]+4
I'm attempting to set a looped program where it goes through and adds 4mm to the Z axis as many times as I tell it to.
However, I can only get the robot to cycle with an offset in the x-axis and y-axis using either a 1 for x or a 2 y where the 3 currently is in lines 19 and 20. Placing a 3 in there instead of a 1 or 2 doesn't work. I assumed a 3 would be for the Z-axis, as 1 works for X, and 2 works for Y, I feel it would be logical that 3 would be for Z. Apparently not? I get an error when I attempt to run the program and it gets right up to where it's about to index over. It throws a code "INTP-204 (PROGRAM TITLE, 19) Invalid value for index"
Again, it works flawlessly when either a 1 for the x-axis or a 2 for the y-axis are put in where the 3 is. As soon as I put a 3 in there, the program always stops right before it executes the first index. Any ideas would be highly appreciated. The goal is to have a program that brings the robot down into place to place a weld on a shaft that rotates on group 2 (rotary table). Then, as soon as the first weld is completed and the gas post flow is done, I want the robot to back up slightly higher and higher essentially laying weld after weld right on top of the previous weld and the previous weld, slowly building up a surface, almost acting like a 3D-printer. I believe I am close with what I have.
