Hallo Evryone,
i have an Old Program. after that program i did two time mastering. now i am trying to run that old program but i am getting the offset that i teached ?
idea: should i do the mstering one more time and will get that points ? will run my programm after mastering?
Mastering
- Nirav Gevariya
If you did the mastering incorrectly then redo it it. If you did it correctly then reteach your program.
i have privious back up . can i load it with master data?
Yes, you can, but the questuion still exists... was it done with proper mastering or not? Check mastering after restoring the backup, then decide and do, as HawkME said.
yes it was done proper mastering. after that someone did mastering and it was not proper. so i did one more time mastering with Zero mastering method and solved the problem.
Thanks for your help.
