Is there a way to calculate the force applied by the robot on a plate. Is getjointforce a function that can help calculate the force applied?, if so can u provide an example of how getjointforce can be used.
Thank you
Thank you
I have any example from the manual,
if bTeach==true
// teaching expected joint force
//zero array of maximum joint force values
for i = 0 to size(nCurrent)-1
nMax[i]=0
endFor
do
//get current joint force array
$getJntForce(nCurrent)
//set maximum value
nMax[i]=max(nCurrent[i],nMax[i])
endFor
//repeat every 4 milliseconds, update rate of servo data
delay(0.004)
// until movement is finished
until isEmpty()==true
else
// to test current motion again maximums
bError=false
do
// get current force
//does it exceed the maximum value plus 10%
if nCurrent[i]>nMax[i]*1.1
//stop the arm and signal the error
resetMotion()
popUpMsg("Joint force higher then expected")
bError=true
endIf
endFor
delay(0.004)
endIf
This teaches the maximum allow force and then is monitoring it.
Put it on a task and test it.
Thank you for the reply,
Will test this code out. Is there any way we can set a constant force on a particular task??
Not that I am aware.
This is probably something you need to refer to Staubli directly.
Don't even know if their robots are capable of being controlled by force.
To use $getJointForce command, you need to instal addOn "Motion" on your controler. Call Stäubli service to know the method for that...
