  4. ABB Robot Forum
IRC5 FlexPendant Check
  • Rainman
  • May 23, 2022 at 8:03 PM
  • Rainman
    108
    I have one IRC5 controller with FlexPenedt Generation TPU3 ,but when I turn on the controller system bootup from flash disk and I can see the motor on button light is lit and blinking .
    in this case on the tech pendent is written ''booting in progress......."
    so I guess the problem is belongs to FlexPendet ,
    to check the FlexPenedt I went to another controller in another place , in that place I have IRC5 controller With FlexPendent Generation TPU2 .
    When I have connected my wrong TPU to this Controller ,the problem ''booting in progress.....'' is written on the FlexPendent screen again ..
    but my question:
    According the test procedures that I have done ,Can I say ,the problem is completely comes from FlexPendent and should be change with new one ?
    Images
      • 91.7 kB
      • 1,080 × 607
      • 8
    Lemster68
    301
    2,489
    Blog Articles
    7
    • May 23, 2022 at 9:22 PM
    I would not say that definitely, because you connected it to an older robot controller which supports the older tpu. Check the connection and the status leds in the controller. With the power off, you can carefully open the pendant and check the connections inside.
  • Rainman
    108
    • May 24, 2022 at 11:10 AM
    Dear Lemster68
    According the ABB web site ,TPU3 is replacement order for TPU2 . it means if you order TPU2 from ABB you will get TPU3 from Them .
    https://new.abb.com/products/3HAC023195-001/3hac023195-001
    According this information my test should ok ,
    Is there any body has same problem that I have ?
    Is there any way to check ABB pendent to be sure should change ?
    Best regards
    Images
      • 251.59 kB
      • 1,900 × 1,003
      • 12
  • Damo
    5
    • May 24, 2022 at 4:12 PM
    Have you tried holding down the Stop button and programmable key 1 at the same time?
    Hold them down until the pendant restarts, this will flash the pendant and it will upload a new image from the PC.
  • Rainman
    108
    • May 24, 2022 at 5:45 PM
    Not, I didn't check the procedure that you have described .
    I just hold down stop button with Programmable Key 4 ,to check pendent goes to calibration screen or not ? after that pendent said ''erasing calibration data '' but unfortunately nothing happened after that .
    normally after that we can calibrate touch screen and also joystick and some other setting .
    Let to check this procedures !!!
  • SomeTekk
    17
    202
    • May 24, 2022 at 6:19 PM
    1st, there isn't some third party cable, or cable reel, used is there? If so try an ABB cable.
    2nd, if you want to reflash the pendant as DAMO suggests, have someone cycle power to the control WHILE the stop AND programmable button number 1 are held down. It is suggested to hold the two buttons down until red text indicates
    Image is not present. Downloading start.
    Release the buttons and wait for the pendant to complete the reflash. Alternatively the reset button on the back of the pendant may be pushed whilst holding stop AND programmable button number 1 down and wait for the red text.
Similar Threads
  • Ethernet/IP Device is faulty configured
    • Landqvisttim
    • March 24, 2022 at 12:41 PM
    • ABB Robot Forum
  • Strange IRC5 failure -- lost pendant and EIP, but RS connection fine
    • SkyeFire
    • January 5, 2022 at 6:47 PM
    • ABB Robot Forum
  • Robot actual override procent
    • RookieWithRobots
    • December 10, 2020 at 9:08 PM
    • ABB Robot Forum
  • Load ID
    • cavan223
    • August 29, 2020 at 10:55 AM
    • ABB Robot Forum
  • IRC 5 Add an I/O Module with profinet
    • Dodo41
    • August 9, 2020 at 3:06 PM
    • ABB Robot Forum
  • ABB Multimove freezing
    • VoCh
    • November 20, 2019 at 6:10 PM
    • ABB Robot Forum
  • Put all Robots on Network?
    • dhlg0110
    • January 30, 2019 at 6:30 PM
    • ABB Robot Forum
