Karel URL set DO
  • bokodimate
  • May 20, 2022 at 2:06 PM
  • bokodimate
    24
    Hi!
    I want to control a fanuc robot's Digital I/O ports from a PC through Ethernet.
    I've found a solution for controlling register from PC, this will set R[1]=10
    robotip/karel/ComSet?sValue=10&sIndx=1&sRealFlag=-1&sFc=2
    Is there a similar option for setting ports? Like DO[1] = ON
    Thank you!
    Edited 2 times, last by bokodimate (May 20, 2022 at 3:43 PM).
  • panic mode May 20, 2022 at 3:25 PM
    Approved the thread.
  • SkyeFire May 20, 2022 at 3:33 PM
  • Lemster68 May 20, 2022 at 4:09 PM
  • rf103
    17
    264
    • May 21, 2022 at 8:15 AM
    You could take a look how https://github.com/gavanderhoorn/dominh does it.
  • HawkME
    567
    10
    3,268
    • May 21, 2022 at 1:46 PM
    There is a DO comment option, but I cannot remember if there is a value option. If not then you could just use a R, and monitor it in BG Logic to set the DO.
  • DS186
    198
    1,048
    • May 21, 2022 at 3:54 PM
    The comment tool only allows you to assign values to Registers.
  • bokodimate
    24
    • May 23, 2022 at 9:57 AM
    Thank you for your replies!
    I've found the solution in rf103 's answer.
    To modify DO from url you can use this:
    DO[1]=ON:
    http://ROBOTIP/KCL/set%20port%20DOUT[1]=1
    DO[1]=OFF
    http://ROBOTIP/KCL/set%20port%20DOUT[1]=0
Similar Threads
  • Momentarily ignoring I/O inputs
    • Robotwhisperer71
    • May 19, 2022 at 8:40 PM
    • Fanuc Robot Forum
  • Fanuc - sending coordinates via TCP/IP with Python
    • James5678
    • May 11, 2022 at 10:08 PM
    • Fanuc Robot Forum
  • Call a program using SR and BG logic
    • Theo.g
    • May 4, 2021 at 2:32 PM
    • Fanuc Robot Forum
  • CR-15iA or R-30iB Plus I/O programming
    • RobotOverlord
    • May 4, 2022 at 8:19 PM
    • Fanuc Robot Forum
  • How to start a program from a remote pc
    • aijim
    • April 26, 2022 at 4:18 PM
    • Fanuc Robot Forum
  • Karel Error when trying to use V_RUN_FIND
    • jariuscs
    • April 1, 2022 at 10:31 PM
    • Fanuc Robot Forum
  • DO
  • http
  • PC
  • url
  • Digital I/O
