STAUBLI CS9-TS2-60
  • Hello
    I have some problem when i try to start the emulator, it puts on STOP and give the error "80:Uses data or a program from a library not loaded in the memory". This error appear when it try to call a function from a library that is empty, have only Begin and End.
    Someone can help me with a solution, what I'm doing wrong
  • Hello,
    If your library is empty, there is no need to call it..
    I'm gonna try to reply anyway:
    With the little you have written, I would guess that you have not changed the access of the "function" (as you call it) to Public.
    The difference between theory and practice is greater in practice than in theory.
