Fanuc UI Inputs
  • TheCraigofCraigs
  • May 19, 2022 at 11:53 PM
  • TheCraigofCraigs
    I am working on setting up a used robot at work. It’s a R-30ib controller. I have figured out where to wire the inputs to start remotely however when I make more than one input at once they all come on. Does anybody know how to correct this issue?
  • panic mode May 20, 2022 at 2:56 AM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
  • hermann
    412
    2,629
    • May 20, 2022 at 6:10 AM
    Correct wiring.
  • TheCraigofCraigs
    • May 20, 2022 at 1:16 PM
    I was able to fix the first problem. Now I am having an issue with a INTP-206 (Interface 3) digital fault. Anyone have any ideas I can’t find anything useful online or in manual
  • HawkME
    570
    3,270
    • May 20, 2022 at 11:54 PM
    Your program is trying to deal with IO that isn't defined.
  • Fabian Munoz
    134
    Articles
    1,517
    • May 21, 2022 at 6:25 PM
    TH
    I could be much much easier for us to give you an answer if you post your UI/UO config
    Retired but still helping
  • TheCraigofCraigs
    • May 21, 2022 at 7:20 PM
    Thanks everyone it was an old job that needed deleted.
  • byrdtool
    • November 10, 2022 at 8:27 PM
    Quote from TheCraigofCraigs
    I had the same issue...You have two or more inputs wired they all come on correct?
    I am using the CRMA15 I/O. This is what the book says
    SDICOM1 to 3 signal are common selection signal for SDI.
    When +24F common is used, connect to 0V.
    When 0V common is used, connect to +24F.
    SDICOM1 Selects a common for DI101 to DI108.
    SDICOM2 Selects a common for DI109 to DI120
    If you're using +24F you need to attach the SDICOM 1-3 to 0V
    See the note: SDICOM1 is for Inputs 101-108 etc.
    Hope this helps. Now I am asking for help.
    How did you wire an external start?
    I cannot get an external button perform the Cycle Start.
    Files
    R30iB Mate Plus CRMA 15 16 CRMA 58 59.pdf 672.46 kB – 43 Downloads
Similar Threads
  • Robot does not move in Manual
    • Mikael
    • January 24, 2022 at 5:42 PM
    • ABB Robot Forum
  • FANUC JUMP AND LBL
    • shriraj lonkar
    • April 28, 2022 at 8:40 PM
    • Fanuc Robot Forum
  • Fanuc UOP how do you increase the number of the UOP Available
    • Robot_guy
    • March 24, 2022 at 1:33 AM
    • Fanuc Robot Forum
  • Ethernet IP connection - Invalid connection size
    • MellingTC
    • November 23, 2021 at 12:18 AM
    • Fanuc Robot Forum
  • Fanuc Equivalent For Group Inputs / Outputs
    • kevilay
    • October 18, 2021 at 4:35 PM
    • Nachi Robots
  • Connecting Fanuc robot to PLC via digital input/output
    • fullbang
    • July 28, 2021 at 12:41 PM
    • Fanuc Robot Forum
  • FANUC I/O Address Mapped I/O
    • Andnet Deboer
    • March 16, 2021 at 2:16 PM
    • Fanuc Robot Forum
  • Roboguide - OPC - TIA Portal. Simulate UOP UI
    • d.chlebek
    • August 23, 2019 at 3:16 PM
    • Fanuc Robot Forum
  • Fanuc Arclink General Welder Setup
    • ChipL
    • September 28, 2018 at 6:14 PM
    • Fanuc Robot Forum
  • Fanuc RJ3ib Process I/O Card inputs and outputs.
    • Napster_matta
    • May 29, 2018 at 7:33 PM
    • Fanuc Robot Forum
