I have 30ib system plus with a 2000ic 210L Fanuc robot. It has 4 positioners, which are groups 2,3,4,& 5. How do I remove group 4 & 5?
- josephtoftjr
- Thread is Unresolved
You can delete the motors out of the group in controlled start. Without reinstalling core software with the personality you want you will not be able to remove the axis modules to my knowledge.
It's possible,
$SCR_GRP[4].$AXISORDER = 0
$SCR_GRP[5].$AXISORDER = 0
Then $SCR.$STARTUP_CND = 12 anc cycle power.
It's possible,
How do you come up with the value to put into $SCR.$STARTUP_CND?
Group 4 & 5 are positioners. I would like to unplug the positioners and move them to a different cell with a compatible robot. If I remove the groups like you recommended, should I be concerned about any DTER errors from the robot that I am removing them from?
Well... I'm not sure, never tried like this. You can always try and you'll get the answear
If the errors exists, you need to delete it from controlled start.
No idea, somehow test and tries
Why do you post Systemvariables with no idea what they effect???
It's possible,
Changing the AXISORDER variable will "mute" the axis (that's my description and my experience). The group will still be able to be switched to through use of the GROUP hardkey.
Using the above variable (the AXISORDER ones), you should not get any DTERR alarm since you are esentially "muting" the axis. I'm not sure what other effects this may have though, so use extreme amounts of caution if you plan on going down this route.
My .02c, just do the job right...Take an Image, take an AOA, take a MNT_DATA backup...re-install the software without Groups 4 & 5. I have "muted" axis before, but that's when we're waiting on motor cables from FANUC or something else is messed up with a positioner or w/e. As soon as I can get the axis back up and running I "unmute" the axis. I've ever only used it as a temporary solution to keep moving forward with an integration project.
I do know the effect, but haven't tested everything for all conditions. Have you?
If it's a problem for you, just don't read it, somebody else use it.
I have no problem with you or your post.
i didn't mean to attack you. but we are talking about machines that cost tens of thousands. in my personal opinion, you should be careful with variables. there are some that can actually damage the machine or can trigger unexpected motions.
C_hiney asked:
Your answer:
Thats why i am ask why you post variables without to know what they do...
So it would be realy nice if you can explain us the effect of $SCR.$STARTUP_CND
We all want to learn.
I couldn't even find $SCR.SARTUP_CND in my variables.
