Windows XPe 2.2 installation repair
  • Gocea
  • May 18, 2022 at 8:30 PM
  • Gocea
    157
    If you don't mind, just one brief question, is there a way to repair Windows XPe Os, something like repair option using installation Cd at Windows XP Os ?
    Thanks in advance.
    SkyeFire
    1,052
    9,429
    • May 19, 2022 at 1:39 PM
    The only method I'm aware of is to completely re-install Windows using the KUKA Windows install CD, followed by re-installing KSS from the KUKA install media, then restoring a backup.
  • Gocea
    157
    • June 22, 2022 at 7:32 PM
    Quote from SkyeFire
    Hello SkyeFfire,
    I just tried to reinstall WinXPe2.2. All installation stages has been performed, Resolution adjustment, Partitioning, etc., except the last one Finishing installation, where after the automatic restart, Windows does not load and the final setup can not be performed.
    The following steps have been tried:
    1. Rebooting with loaded standard Bios values;
    2. Rebooting with disconnected CD drive.
    HD formatting has been done before installing the OS.
    My question is, what could be wrong there? The original Kuka Hdd contains Kuka.CPC software which prevents unauthorized installation of additional software. In that direction is there a possibility for any protection from a new OS installation, also?
    Images
      • 181.73 kB
      • 1,080 × 790
      • 12
  • jesusvaricap
    259
    • June 26, 2022 at 12:25 AM
    Try to use a new HDD without any protection
  • Gocea
    157
    • June 26, 2022 at 1:46 PM
    Quote from jesusvaricap
    I used SSD for the new OS installation. This SSD works fine when the original Kuka HDD is cloned on it. So, the problem during OS installation is not connected with the SSD has been used, probably.
    I found difference at the SSD boot.ini file, comparing with the boot.ini file at the original HDD, as a possible reason why the OS installation does not continue after reboot.
    ... /noexecute/Alwaysoff at the SSD boot.ini
    ... /noexecute/pcilock at the HDD boot.ini
    Your oppinion?
    Images
      • 298.48 kB
      • 1,600 × 1,200
      • 6
    Edited once, last by Gocea (June 26, 2022 at 6:57 PM).
  • Gocea
    157
    • June 26, 2022 at 1:48 PM
    Images
      • 125.48 kB
      • 1,920 × 325
      • 16
      • 151.92 kB
      • 1,920 × 351
      • 9
Similar Threads
  • Install new software
    • Omid1365
    • January 16, 2022 at 10:44 AM
    • KUKA Robot Forum
  • repair
  • XPe 2.2
