Fanuc Collisions - Roboguide
  • lemon132
  • May 17, 2022 at 9:47 AM
  • lemon132
    14
    Hello guys,
    Is it possible to use DCS in roboguide in order to check if the robot is in a certain zone without the alarm ? i want the robot to enter the zone and keep running, at the same time i want an output telling me that the robot is in the zone. Actually, when robot enter a DCS zone it stops with an alarm.
    If not, is it possible with another option, other than DCS ?
    Thank you.
  • Go to Best Answer
  • Roboticien12
    15
    • May 17, 2022 at 11:14 AM
    Hello Lemon,
    Yes it possible, you can do instruction belows:<
    1- define your DCS Zone (exemple DCS Number 1).
    2- in "STOP TYPE" ( dcs parameters) : chose"Not Stop "
    3- in your I/O configuration parametres, define the input that your want to use, for exemple 1, as below
    RAck = 36, Slot = 6, Stat =1
    it's all, you will see that if the robot is in your DCS zone it will not stop and the input number 1 will turn to OFF.
    off course, if you want to use an output you can use INTERCONNECT DI->DO
    Edited once, last by Roboticien12 (May 17, 2022 at 11:52 AM).
  • Roboticien12
    15
    • May 17, 2022 at 11:15 AM
    • Best Answer
    also you can use The space Check function, it's simple then DCS
  • lemon132
    14
    • May 17, 2022 at 11:50 AM
    Thanks a lot
  • DS186
    200
    1,072
    • May 17, 2022 at 12:13 PM
    Quote from Roboticien12
    Be careful with the space function, because it is only monitoring the TCP of the active tool. I normaly prefer DCS with a "No stop" zone to monitor the complete physical tool.
Similar Threads
  • Where to Learn iRvision and Line Tracking
    • PPP
    • June 17, 2021 at 4:55 AM
    • Fanuc Robot Forum
  • Cubic-S, Thoughts/Opinions/Best Practices
    • ericwiz7923
    • March 2, 2020 at 2:04 PM
    • Kawasaki Robot Forum
  • New to Kawasaki robots help with Software
    • ericwiz7923
    • November 12, 2019 at 2:12 PM
  • Jt1 System Axis Limits
    • kwakisaki
    • October 9, 2019 at 6:37 PM
    • Fanuc Robot Forum
  • collision
