  4. Stäubli & Bosch Robot Forum
difference between Taskcreate and Taskcreatesync
  • Rahul Sajeev
  • May 9, 2022 at 8:42 AM
  • Rahul Sajeev
    I wanted to know the difference between usage of taskcreate and Taskcreatesync in Val3. I went through the val3 documentation but couldn't understand how both varies when we use it in a Val3 application. It would be better if an example could be provided.
    Thank you
  • JeffBO
    13
    • May 9, 2022 at 2:18 PM
    Hi Rahul,
    In a few words :
    TaskCreate : Task is executed "continuously" depending on the given priority level.
    TaskCreateSync : Task is executed every x.xx second. Priority level is 3000 (factory setting, can't be modified).
    Example :
    TaskCreate "MyTask",50,ExecuteATask()
    --> Function ExecuteATask() is executed once, with a priority of 50. You can have an infinite loop in your function.
    TaskCreateSync "MyTaskSync",0.5,bOverrun,ExecuteASyncTask()
    --> Function ExecuteASyncTask() is executed every 0.5 second.
    bOverrun=true : function is executed to the end, even if it takes more than 0.5s
    bOverrun=false : function is killed if not completed after 0.5s
    NEVER use infinite loop in such a function, otherwise your CPU will run out of resource.
    Hope this helps,
    Jeff
  • Rahul Sajeev
    • May 10, 2022 at 8:11 AM
    Thank you for the reply
    when I used the TaskCreate and ran the function, It showed invalid task name
    TaskCreate sFilling,10,Task()
    This was the code I used but it showed invalid task name
    Edit: I tried using a normal string instead of using a string variable and it worked. Thank you for your help
    Edited once, last by Rahul Sajeev (May 10, 2022 at 11:00 AM).
  • ElEsgalho
    17
    119
    • May 12, 2022 at 4:06 PM
    Quote from JeffBO
    Hi Rahul,
    In a few words :
    Example :
    Hope this helps,
    Jeff
    I couldn't say better.
    Just adding some more recomendation about TaskCreateSync, please keep it simple and small. As Jeff said, your CPU will run out of resources.
    Also, you are only allowed to have 2 sync tasks simultaneously, I would say 99% percent of the time you don't need a sync task, normal tasks are fast and reliable enough.
  • Galet
    19
    141
    • August 11, 2022 at 2:23 PM
    Are you sure that the value of sFilling is correct ?
  • mil3k
    15
    71
    • August 18, 2022 at 3:00 PM
    Quote from Rahul Sajeev
    Did you create sFilling global variable before you tried to use it? It should find it in Application's Data tab inside string variables branch.
  • Galet
    19
    141
    • August 19, 2022 at 8:21 AM
    Be carreful that the structure of taskCreate and taskCreateSync are not the same :
    taskCreate sName, nPriority, program()
    taskCreateSync sName, nPeriod, bOverrun, program()
    If you don't use good parameters the line is invalid !
    Other thing :, be carreful of uppecase and lowercase of the key words and variable. In Val3 program, you need to respect everytime the script.
    Try le line :
    taskCreate sFilling,10,Task()
    Edited once, last by Galet (August 19, 2022 at 8:26 AM).
  • VAL3
  • tx260
