I have a Fanuc 2000iC 210L that will not jog above %50 override. I went into variables and changed it to %100, it takes the change but will still only go up to %50. I have also checked GENOVERRIDE. Any suggestions?
$SCR.$jogovlim ???
- josephtoftjr
- Thread is Unresolved
Did you check all of the override variables located under $SCR? Are you trying to jog the robot with the fence open? If so, check $SCR.$SFJOGOVLIM. If I remember correctly the default value of this variable is 50.
By the way, this thread should be in the Fanuc forum section.
kwakisaki
Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
Set $scr.runovlim also, then reboot and try it.
Hello, Does the robot have calibration?
