KRC2 drives contactor status signal/output
  • Hello everyone,
    I'm looking for an output signal (or better a system variable) that can be read
    to obtain the "drives status" or the drives contactor on/off signal,
    equivalent to the green "I" on the pendant that stands for "Drives ready";
    $DRIVES_ON tricked me to think to read it, but it is obviously only an input used in Automatic External mode.
    (I'm using the robot in T1, T2 or AUTO)
    I need to use it to drive an external device, so I'm thinking of routing it to an output in SPS.SUB
    Anyone knows something about that?
    Thank you
  • I remember a few threads discussing "simuate EXT (kind of)" without a plc using inputs (buttons) and outputs (even with examples).
    Check your I/O configuration for $IN[1025] for true and $IN[1026] for false (these numbers needs to be replaced by real input numbers).
    Also check the documentation for EXT
    Search yourself while I will search my docs to find the link (this forum - mybe EN or DE)
