Fanuc TcP
dhyeeyy -
April 10, 2022 at 3:46 AM -
What do you mean by
it’s not working out for this tool.
It's a question just like
My car doesn't drive anymore, what can I do?
For a tool like that I would try to calculate the several tcp. Just measuring one of them. May be you have one that is aligned to flange system, then I would calculate all orientations, otherwise measure one of them with, think it is 6 point method, and calculate the other in relation to this one.
13 TCP's.
On a Japanese robot.
That will never work.
You need to get your spirit cleansed. I am already setting up an appointment for myself just for replying to this thread.
Make a toolframe for one of the fingers using the 3 or 6 point method. (pos 0)
Make another toolframe by the same method for the next finger (pos 1)
Write down the difference between the toolframes.
Now you can calculate the toolframe for each finger and by changing the toolframe itself you can select each finger.
Pos 0 = no change.
pos 3 = pos 0 + 3 times the difference.
pos 11 = pos 0 + 11 times the difference.
Etc.
When I look at your foto, I think a simple rotation on one axis is enough.
That is much easier and more precice.
