  4. ABB Robot Forum
Robot program control (need help)
  • Dodo41
  • April 7, 2022 at 8:40 AM
  • Dodo41
    64
    Hello everyone. I have a question for you, I have multiple module and Routine files. Every routine works with signal control if the robot is going to move. For example, if the 1st Module is the main module, I want a routine file connected to the 2nd module to run automatically when the robot is in automatic mode, when the signal for the routine work that is connected to the 2nd module comes. it works, how can i do that? Another question I have is, is there a signal to understand whether the robot is working at the moment? If not, how should we create it? Thank you from now.
  • Go to Best Answer
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • April 7, 2022 at 1:56 PM
    A procedure call should work to call any routine in any module so long as that routine is not declared local to the module in which it is resident. You can configure io signals that you can turn on when in a routine and off as you exit that routine.
  • Dodo41
    64
    • April 7, 2022 at 4:16 PM
    Thank you for your support but I don't quite understand what it means to declare locally as I don't understand English very well, can you show me an example?
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • April 7, 2022 at 4:33 PM
    • Best Answer
    MODULE MYModule
    PROC myProc()
    stuff here
    ENDPROC
    ENDMODULE
    MODULE MYModule
    LOCAL PROC myProc()
    stuff here
    ENDPROC
    ENDMODULE
Similar Threads
  • Tips for buying used robots
    • yogesh
    • August 19, 2010 at 5:57 AM
    • General Discussion of Industrial Robots Only
  • Re-commissioning Our AW-005CL
    • Grasponer
    • December 21, 2021 at 8:16 PM
    • Panasonic Robots
  • Kuka auto external control
    • Vasya Kazmin
    • August 4, 2020 at 8:40 AM
    • KUKA Robot Forum
  • 24v analog outputs FANUC R-J3
    • Mark Krohn
    • March 24, 2020 at 12:12 PM
    • Fanuc Robot Forum
  • RJ3 + Lack of Background Task Capability
    • MMCINTIRE
    • February 4, 2020 at 3:08 PM
    • Fanuc Robot Forum
  • Some PMs
    • panic mode
    • January 28, 2020 at 4:58 PM
    • KUKA Robot Forum
  • KUKA KRC2 OfficeLite 5.2.OL FLEXlm License Finder
    • EngineerTex
    • December 17, 2019 at 5:23 PM
    • KUKA Robot Forum
  • [Solution] Robotiq Gripper 2F85 with Kuka LBR IIWA using Ethercat
    • kiiwa
    • April 18, 2019 at 11:59 AM
    • KUKA LBR IIWA
  • Fanuc lr mate 200B i
    • Carlos Koch
    • December 15, 2018 at 5:34 PM
    • Fanuc Robot Forum
  • Understanding cell.src
    • iDio
    • May 15, 2018 at 8:57 PM
    • KUKA Robot Forum
