Teach pendant issues
  • Binxnsugar
  • April 6, 2022 at 4:59 PM
  • Binxnsugar
    10
    Alright, so I cannot get my TP to do the normal on/off with the switch. Everything else works, the buttons down to the Estop. It is giving me these codes
    Servo-248 deadman abnormal (when in auto)
    And
    Servo 199 & 233 when in T2.
    I am self taught and have no idea what to do, or if I should go get our maintenance department in on this.
    Is this fixable on my own?
  • Binxnsugar
    10
    • April 6, 2022 at 5:36 PM
    And now I’m also getting SYST 034 Hold signal from SOP/UOP is lost
  • Nation
    Typical Robot Error
    524
    1,903
    • April 6, 2022 at 5:59 PM
    Sounds like you may have a bad teach pendant cable. This is more of a guess though. I'm not super strong on the hardware side of things.
    You might be able to clear the deadman fault by bring the deadman in and out multiple times. Also, I'm not sure if it needs a single channel reset when that fault shows up, but go into the alarm menu and hit reset single channel in there just in case, which I think is F3.
  • Binxnsugar
    10
    • April 6, 2022 at 6:21 PM
    I will try right after lunch, and fingers crossed because I don’t know anything about fixing most of this stuff. I had 3 days of training and everything after that I’ve figured out on my own. (That was 2 years ago) I’m now the only one here that know how to run this thing. (Which is scary)
  • Binxnsugar
    10
    • April 6, 2022 at 7:22 PM
    Small update, the reset thing didn’t work and I can’t find maintenance to get the new cable, so that’s fun.
Similar Threads
  • Hobby Robotics with VS-6354CM & RC3-V6A
    • mcardoso
    • February 16, 2022 at 3:06 PM
    • Denso Robot Forum
  • Robot TCP Vibration Issue
    • yasman
    • July 7, 2021 at 9:31 AM
    • Yaskawa Motoman Robot Forum
  • BG logic issue
    • Bootsman1
    • September 29, 2021 at 11:09 PM
    • Fanuc Robot Forum
  • Main CPU LEDS and ALARMS
    • AleynaKiratLi
    • March 22, 2021 at 12:57 PM
    • Fanuc Robot Forum
  • Rj2 issue teach pendant boots up To ready screen and froze
    • manucnc
    • November 25, 2018 at 1:14 AM
    • Fanuc Robot Forum
  • Teach Pendant software fail
    • Dev0
    • January 25, 2021 at 8:52 AM
    • KUKA Robot Forum
  • Teach pendant of R-J3iB controller freezes due to network
    • Bas0601
    • January 12, 2021 at 6:29 PM
    • Fanuc Robot Forum
  • Error 1556
    • ericwiz7923
    • June 17, 2020 at 3:56 PM
    • Kawasaki Robot Forum
  • Where to find UALARMs in a backup
    • K-Sky
    • January 4, 2017 at 4:46 PM
    • Fanuc Robot Forum
  • Utility of KAREL Programming?
    • StoopidEngineer
    • April 22, 2019 at 11:10 PM
    • Fanuc Robot Forum
