INVERSE
  • KK_Robotics
  • April 5, 2022 at 2:46 PM
  • KK_Robotics
    14
    Hello.
    I have some trouble with the Inverse Fuction in KukaSIM.
    I try to use the INVERSE Function, to check if i can reach my Position,
    and if i cant reach my position, i will try to recalculate it.
    The problem is that, even if i cant reach the position, the err_Status never gives me a faultcode.
    Anyone have some suggestions?
  • panic mode
    1,268
    13,040
    • April 5, 2022 at 8:19 PM
    1. what is this "err_status"?
    2. what is the "WAIT TIME 0.1" command?
    3. how are you testing?
    example out of reach check with iError value 2
  • KK_Robotics
    14
    • April 11, 2022 at 9:31 AM
    "Err_Status" is what Kuka calls the "iError" in the manual.
    The "WAIT TIME 0.1" Command, is a fault, should be "WAIT SEC 0.1"
    And i am currently testing it, in KukaSIM4.0, but maybe that is the problem?
  • panic mode
    1,268
    13,040
    • April 11, 2022 at 1:45 PM
    The problem is that you are only mentioning name of the tool used rather than posting actual details that would make it possible to reproduce your attempts....
    in other words, what is the robot type, what are the values you are working with and what results you get?
  • KK_Robotics
    14
    • April 20, 2022 at 8:33 AM
    The Robot is a KUKA KR 240 R3200 PA - 4 Axis.
    It seems that everytime i have angle value In my E6POS other then 0, the calculated angle on axis 2 is wrong. Its like it "Forgets" That the tool is rotated -180
    Example 1:
    E6Tmpt=(x 600, Y 468, Z 445, A 0)
    E6Result = INVERSE (E6Tmpt, $Axis_ACT, iError)
    E6Result.A2 is equel to the actuel A2 axis Pos when the robot Reach the POS.
    Example 2:
    E6Tmpt=(x 600, Y 468, Z 445, A -180)
    E6Result.A2 is NOT equel to the actuel A2 axis Pos when the robot Reach the POS
    But if i move the robot to the "Pick" position, with a nonrotated tool, the calculation will match the actuel position.
    (E6Result.A2 = -21) But the actuel axis pos will be (-5)
    Make sense ?
  • KK_Robotics
    14
    • April 20, 2022 at 10:26 AM
    I tried to use like -171 instead of -180, just to varify that its not a problem at its from 0 to -180.
    its like that the simulation is ignoring my tool rotation
  • Fubini
    272
    1,873
    • April 20, 2022 at 12:22 PM
    Are you familiar with ambiguities caused by status and turn? Read about $TARGET_STATUS and the meanings of iError as input value.
    Fubini
  • KK_Robotics
    14
    • April 21, 2022 at 7:52 AM
    It is stated in the manual that you only need the start_Axis if you have no Status or turn value, or that you are close to singularity.
    I tried before i removed the "Start_Axis" to write "$Target_Status=#SOURCHE", but the result was the same.
    The calculated result was = -28, but the actuel pos was -20.
    Then i tried to remove the "Start_Axis", with the same result.
Similar Threads
  • Robot kuka devicenet
    • Reiner Berbesi
    • February 15, 2022 at 12:04 AM
    • KUKA Robot Forum
  • Unreachability check
    • Mohamad Sayegh
    • February 1, 2022 at 11:49 AM
    • KUKA Robot Forum
  • Finding 8 different solutions of KUKA robot in KRL programming
    • Uthiralakshmi s
    • August 25, 2021 at 9:26 PM
    • KUKA Robot Forum
  • Karel Program
    • cobotrobot
    • December 1, 2020 at 2:55 AM
    • Fanuc Robot Forum
  • Base transformation
    • benjamin21
    • August 11, 2020 at 1:23 PM
    • KUKA Robot Forum
  • Direct and Inverse Kinematics of an ABB IRB 120 Industrial Robot
    • ilian.bonev
    • April 28, 2012 at 2:52 PM
    • Robot Geometry, Linear Algebra, Forward and Inverse Kinematics
  • Frame Transforms
    • atomic_robo
    • June 28, 2018 at 6:55 PM
    • KUKA Robot Forum
  • Finding axis angles with INVERSE
    • arikrundquist
    • June 29, 2018 at 10:44 PM
    • KUKA Robot Forum
  • inverse kinematics
  • kukasim
