So recently i installed motosim and trial key ony my company's pc but after i opened the program it still asked for the "hardware key".
Basically installing the trial key did nothing. Did i do something wrong?
Best regards,
Bruno Nogueira
Best regards,
Bruno Nogueira
After install the Motosim, don't open software, open trial license setup file and run it.
After install the license key it doesn't give you this message.
Could also be regional. The free trial is from Yaskawa Europe. Outside this region it may not work.
Yea i did that and still didnt work. I installed at my work pc and home pc, both not working.
Im from Portugal btw so im from Europe.
When you get the trial license file from Yaskawa portal?
You need a key.
You need a key.
Yes i know, i used the free trial key yaskawa is offering .
Contact Yaskawa directly and explain them the problem.
I did that already about two weeks ago and got no response. What i did was disabling windows defender on my home pc and install both motosim and trial key and then just worked.
You must give trial key when you will install Motosim, my means is if your trial key is old it could not work now and you must give a new trial key.
