KRC2 read number from KCP
  • Milan
  • March 23, 2022 at 9:50 PM
  • Milan
    13
    At dispensing application, I want to ask customer to enter dimensions of the workpiece and robot will perform trajectory defined by offsets (x and y directions) from the starting point.
    In ABB Rapid, this is TPRead instruction, but I'm not aware which instruction is KUKA KRL equivalent.
    Variable could be INTEGER data type.
    That values are different from time to time and cannot be fixed by program.
    Is the any way to realize that?
    Many thanks for support.
    Zeljko
  • panic mode
    1,280
    13,083
    • March 24, 2022 at 7:17 AM
    in KRL one would use geometric operator to add offset.
    DECL FRAME Shift
    Shift = $nullframe ; all 6 elements zeroed (must initialize them all)
    Shift.Y = 33.6 ; mm (this could come from where ever you like)
    PTP P1
    PTP P1:Shift
    PTP P1
  • Milan
    13
    • March 24, 2022 at 8:15 AM
    Many thanks for you support, but I need info how to read number from KCP keyboard, first.
    Later on, once I store number (integer) into variable, lets say Y.dir, then I can use it for:
    Shift.Y = Y.dir;
    Some advice?
  • panic mode
    1,280
    13,083
    • March 24, 2022 at 1:00 PM
    Integer will likely be too coarse, it is probably better to stick with real.
    It is not clear what you are asking. It appears that you want to make changes at runtime. This is dangerous as any typo can send robot on a collision course.
    Normally values are changed by editing file or value using single variable monitor or variable overview. Better way is to use inline form created with UserTech.
    Another option is to read parameters from a file using CWRITE. Then there is an option to use dialog as a keypad. There is also fancy option using add-on software like myHmi or EasyHMi or Zenon or numeric entry from OrangeApps. And if you know enough you can make your own.
    Btw if you are ok with integers, why not use built in and almost never used functionality - counters ...
    twenty counters are already shown and editable by HMI.
  • verove
    73
    • March 24, 2022 at 3:08 PM
    Hey Milan,
    Quote from Milan
    I'm unsure that KRL has a specific function that matches the TPRead Rapid instruction. But, it does have a dialog pop-up option. Check out the message library (MsgLib.scr / MsgLib.dat) for this.
    You can create a dialog box with up to 7 softkeys and they can be used to select certain answers. Whatever key is pressed, will return a value (similar to the nFnKey in Rapid).
    So if you have predetermined values that the user needs to choose from, you can use the first 6 keys as options and the last softkey as a "Next Page". It'd work something like this:
    MsgDialog(DialogAnswer, "Please choose: blue or red?","Cell",, "BLUE", "RED")
    IF (DialogAnswer==6) THEN
      ;color is red
    ELSE
      ;color is blue
    ENDIF
    SkyeFire
    1,052
    9,427
    • March 24, 2022 at 5:01 PM
    Sadly, KRL doesn't have an equivalent of the RAPID TPRead, only an equivalent of the TPReadFK.
    OrangeApps.de offers an option package that provides similar functionality, but I'm not sure how much it costs.
    I've attached a somewhat crude workaround example I wrote a while back to "dial" a value in using the softkeys.
    Files
    DialASetting.zip 1.41 kB – 10 Downloads
  • variable
  • Number article
