RSI Block Diagram Editing/Generation
  • cnicho35
  • March 22, 2022 at 6:51 PM
  • cnicho35
    10
    Part 1:
    I am trying to configure an RSI application to set the axis positions from an external controller. I have this example RSIX file which is doing PosCorr but I want to do AxisCorr and it seems as simple just replacing the PosCorr block with an AxisCorr block but I cannot find information on how to edit the diagram and add/replace blocks. Does anyone know how to edit the block diagram?
    Part 2:
    Also, I have an older example RSI application which has the following files:
    RSI_Ethernet.rsi
    RSI_Ethernet.rsi.diagram
    RSI_Ethernet.rsi.xml
    RSI_EthernetConfig.xml
    (from ROS kuka_experimental for those curious)
    Is there a way to convert these files to an rsix file? If I drop them in the SensorInterface folder on the KRC4 controller, my application does not work like it does for the example rsix file.
    Any help would be greatly appreciated.
  • Go to Best Answer
  • cnicho35
    10
    • March 22, 2022 at 6:55 PM
    Link to files listed above:
    https://github.com/ros-industrial…rface/krl/KR_C4
  • SkyeFire
    1,062
    9,465
    • March 23, 2022 at 1:39 PM
    RSI comes with the installer for the editor RSI-Visual. That is the program you must use to edit RSI programs in KSS 8+
  • cnicho35
    10
    • March 23, 2022 at 2:42 PM
    Thanks for your reply! Going by this thread, I can find the installer for that program at D:\KUKA_OPT?
  • SkyeFire
    1,062
    9,465
    • March 23, 2022 at 3:36 PM
    Quote from cnicho35
    KUKA_OPT\RSI, yes.
  • cnicho35
    10
    • March 23, 2022 at 7:30 PM
    It appears I have RSIVisual but I see no way to add/remove/edit the blocks on the diagram. If I want to add an AxisCorr block, how would I go about doing that? How about a debugging block?
  • massula
    205
    8
    1,440
    • March 23, 2022 at 11:50 PM
    Go to Window menu and select Toolpanel option.
    It will open another tab at the same place where catalogs window is located.
    RSI options will appear there only if You have an RSI context file opened. Otherwise, Toolpanel will be blank.
  • massula
    205
    8
    1,440
    • March 23, 2022 at 11:58 PM
    • Best Answer
    Like this.
  • cnicho35
    10
    • March 24, 2022 at 11:06 PM
    Nice, thank you!!
  • I-reeningne
    • May 29, 2024 at 9:00 PM
    cnicho35 How did you solve part 2 of your problem? I have run into the same issue
  • cnicho35
    10
    • May 30, 2024 at 5:04 AM
    • #11
    Nope, no way to convert old rsi files to the new rsix files unfortunately
Similar Threads
  • New to Kuka iiwa programming---error when I try to run program that i created
    • ScottS
    • July 29, 2020 at 1:41 PM
    • KUKA LBR IIWA
  • KCR4
