Hi All,
KRC4 8.6.6
PalletTech 4.0.0
I have a configuration question around multiple item infeed for PalletTech Cells.
I have 3 Infeed Stations, which are fed from product lines that can generate up to 5 different products each.
The lines produce one product at a time, no mixed product.
To change product, the line is paused, the machines are changed over upstream, and the line is restarted.
Each line has a pallet space for the specific Palletization for that product.
All products are a different item size and pallet pattern.
In Pallet Tech, you might set this up as a Scenario with 3 Infeeds, 3 Outfeeds, and 3 Palletizations:
Line 1 - Product 1 - Palletization 1
Line 2 - Product 2 - Palletization 2
Line 3 - Product 3 - Palletization 3
If you change Line 1 from Product 1 to Product 4, You would need to create another scenario:
Line 1 - Product 4 - Palletization 4
This works fine, but presents an issue:
5 Products per line * 3 Lines = 125 Scenarios
What are my options here besides programming 125 individual scenarios?
