IRB6700, IRC5, RW 6.12
I have a set of new IRBs that are being much more difficult about recovering from jog collisions than I've become accustomed to. The really strange thing is that, when attempting to jog the robot off a collision, it'll move slightly, then stop again on the Motion Supervision fault. Normally, I would expect that I would need to clear the fault, re-engage the motors, and jog a bit more before it faults out again. Lather, rinse, repeat until I get the collision pressure off the axes.
But on these robots, when I re-engage the motors, the robot will "jump" back to where it was previously (before I touch the joystick), undoing whatever pressure relief I managed to achieve before it faulted out. It's quite bizarre. It's almost as if the robot is trying to do a path recovery the moment the motors come on, but it shouldn't be doing that, and it just makes the situation worse. I literally got stuck in this loop for an hour one one robot before I got fed up and tried the "brake release" buttons on the side of the Joint 1 casting.
These robots are "stock", straight from ABB with no option packages or setting customizations in the Motion parameters. The Tool and Payload ID have been done, and the correct Load data was active while this was happening. Is there a setting that we might have wrong, that could be causing this?
