Fanuc robot R30iB connection to KEPServerEX
  • ckv
  • March 10, 2022 at 5:09 PM
  • ckv
    Hello everyone.
    Have a Fanuc Robot R30iB controller working with a moulding cell locally (on port 1 CD38A) but configured to our network with required IP (port 2 CD38B). We want to collect the internal registers data from the robot controller.
    I read through the Internet options Manuals and the manuals from Kepserver drivers and several threads and will define the persisting problem here.
    Having configured the Robot IP to the one in our network, I am able to access the FTP server and the Webserver of the machine. Want to view those tags in Kepware.
    Have defined the Channel as GE Ethernet and the GE OPEN protocol which I believe is the SRTP protocol. From the FTP server, imported the 'summary.dg' configuration and believe that we have SNPX driver installed on the machine. See below:
    SNPX basic SNBA
    Socket Messaging R636
    TCP Auto Set J520
    TCP/IP Interface HTCP
    TMILIB Interface TMIL
    TP Firmware R789
    TP Menu Accounting TPAC
    TPTX TPTX
    Telnet Interface TELN
    Tool Offset J509
    Torque Simulator I/F J882
    Touch Panel R781
    Trouble Diag. & Prev. J958
    USB port on iPendant J957
    Unexcepted motn Check UECK
    User Frame UFRM
    VCalibration Common VCCM
    Vision Core VCOR
    Vision Library VIPL
    Vision SP CSUI CSUI
    Vision SP CSXC CSXC
    Web Plus WEBP
    Web Server HTTP
    Web Svr Enhancements R626
    iPendant CGTP
    iPendant Grid Display IGUI
    iPendant Setup IPGS
    iRCalib. Standard IRCL
    ARC Mate 120iC H844
    AutoSingularityAvoidM R512
    CE Mark J618
    Collision Guard R534
    Collision Guard Pack J684
    Constant Path R663
    Cycle Time Priority J523
    DCS Pos./Speed check J567
    DHCP R526
    Domain Name Serv. J755
    Ethernet/IP Scanner R785
    FRL Params R651
    HMI Device (SNPX) R553
    Integrated PMC J760
    Internet Conn/Custo R558
    PC Interface R641
    PMC Change Mode R652
    Password Protection J541
    SNTP Client R610
    Singularity Avoidance R792
    64MB DRAM D064
    64MB FROM F064
    The other options defined in the Channel.Device in Kepware follows default settings with PLC settings -> Program name changed to LADDER (Not entirely sure if this part is true..?) and the Communication settings -> TCP/IP port 60005 (default was 18245). [Did some debugging, but 18245 always tried to reset the socket when observed through Wireshark and 60005 is another TCP/IP port that was open on the machine controller found using nmap].
    With different combinations of port values, the Quick Client always returned data with BAD quality and Unknown value. The connection seems to go through as the Synchronous device read succeeds but still the data quality fails. see attached. the attachment also shows some inherent system tags that comes along with the driver that do not read any data from the machine.
    P.S. I have not configure anything on the machine itself as it was done by the machine integrator.
    Am I missing something? Do i have to do something on the machine side to enable this data transfer.
    I did some debugging and from the 'ethernet.dg' file I find that connection request through port 60005 is ESTABLISHED but data doesnt seem to come through. Specifically I want to read the Internal numerical registers R[*] into the KEPServerEx.
    Any pointers are greatly appreciated.
    Thanks in advance.
    Images
      • 35.11 kB
      • 1,272 × 712
      • 62
  • Raczark
    • December 4, 2023 at 7:16 PM
    Hi ckv, you need the HMI DEVICE SNPX installed in your robot to establish your comunication
  • maugustyniak
    • February 8, 2024 at 6:44 PM
    Hi ckv, I have the same problem. The device is not responding. Were you able to solve your communication problem ?
  • data
  • r30ib
  • kepware
