Wiring a Limit Switch to an RI
  • EPeters1
  • March 8, 2022 at 4:26 PM
  • EPeters1
    8
    111
    I want to set up a limit switch that will send a signal to RI. I attempted to wire it into the CRF7 connector, connecting the switch to an RO on one side and RI on the other. My idea was to keep the RO permanently on sending a signal to the switch and then when the switch is tripped it would complete the circuit and send that signal back to RI. Has not worked. What am I doing wrong? I am very new to the RI/RO side of things so im not surprised it didnt work first try but I cant seem to find clear instructions how to do what I want to do.
    Its an Rj3iB controller and an Arcmate 120iB robot if that affects things at all. Thanks for any help you can give.
    Nation
    Typical Robot Error
    529
    1,908
    • March 8, 2022 at 4:56 PM
    ROs on that era controller are sinking (NPN), not soucing (PNP) like they are on newer controllers.
    When you turn an RO on, it just provides a path to ground.
    You will need to feed 24v through your switch, and then back to your input.
  • EPeters1
    8
    111
    • March 8, 2022 at 5:25 PM
    That makes sense, thank you
  • pdl
    266
    1,506
    • March 9, 2022 at 3:05 PM
    What is the purposes of the limit switch? Are you trying to protect equipment or people?
  • EPeters1
    8
    111
    • March 10, 2022 at 1:29 PM
    It's simply to send a signal into the robot so it can determining what part is in front of it. We often have alternating components but sometimes operators will load the same one twice in a row and then the robot runs the wrong program. With the switch in place one part will trip it and one part won't so it can read that signal and run properly even if the operator loads wrong.
  • hermann
    405
    2,596
    • March 10, 2022 at 1:40 PM
    You need the pinout of the EE connector on the arm. You can find it here:
    Arcmate 120ib Hand Broken Connector
    then connect +24E and RDI1 to your switch.
  • EPeters1
    8
    111
    • March 10, 2022 at 8:36 PM
    Everything is working, thanks for the help everyone. I should have just started here instead of going on my own understanding, could have saved me a day haha.
Similar Threads
  • Error 90214 Limit Switch open, DRV1
    • Ayoub
    • June 23, 2021 at 3:21 PM
    • ABB Robot Forum
  • wiring
    • davidpirie
    • February 23, 2021 at 9:12 PM
    • General Robotics Discussions - everything but NO Industrial Robots
  • Yaskawa YRC1000 Alarm Codes 4740 and 4747 [1]
    • Cappy3892
    • December 29, 2020 at 8:04 PM
    • Yaskawa Motoman Robot Forum
  • TPU lost contact after insert boot disc (SOLVED)
    • case25
    • November 30, 2017 at 1:46 PM
    • ABB Robot Forum
  • S4C+ error 20209 External Contactor open
    • schelle
    • January 8, 2020 at 11:00 AM
    • ABB Robot Forum
  • Error 20201 limit switch open solution
    • Gallagej
    • June 12, 2018 at 7:39 PM
    • ABB Robot Forum
  • Connecting T1/T2 to fence circuit
    • TitusLepic
    • October 17, 2018 at 6:06 PM
    • Fanuc Robot Forum
  • Kawasaki UX150 A55 Help required to return to life
    • Nzhuhu
    • July 10, 2018 at 2:13 PM
    • Kawasaki Robot Forum
