Is there a way I can highlight my comment within a program? Yellow for example?
New to yaskawa, fanuc is my bread and butter.
TIA.
TIA.
You don't say what generation of controller. Probably SETUP in the Main Menu, then DISPLAY COLOR COND.
Yrc100 controller.
95devils said, go to SETUP menu and then DISPLAY COLOR COND.
You can define color for each instructions that you need same as comment.
Ok thanks, I was able to do that...
But what about having the entire text area to highlight with the background?
If I were to use a highlighter on a piece of paper, to really make it stand out?
Colors are based on instructions. You can’t highlight a section. Closest is all the same type of instruction back to back to back.
