  4. Stäubli & Bosch Robot Forum
How to change input/output name?
  • mil3k
  • March 8, 2022 at 9:07 AM
  • mil3k
    21
    84
    Hi all,
    I use Ethercat I/O coupling to control end effector. At the moment I can see I/Os as ChannelNo.Output and ChannelNo.Input. Is there any way to change "ChannelNo" into something more human friendly?
  • Go to Best Answer
  • Johnsenfr
    • March 8, 2022 at 12:11 PM
    Do you use a CS9 or CS8C controller?
    If CS9, did you create an EtherCat Master at J206? What´s your slave?
    We need some more information to help you.
  • Psyril
    18
    83
    • March 9, 2022 at 9:58 AM
    with the EtherCAT slaves from Stäubli, I found a workaround to be able to rename the inputs/outputs. Although, it might be possible to do it in SRS by now.
    1. In SRS (SyCon), create the J206 Master and add the slaves to it
    2. Close your cell
    3. With "Windows Explorer" go to the location of your cell CELL\CONTROLLER_NAME\usr\configs\J206_EtherCAT
    4. open the file "J206_SyCon_ENI.xml" with a text editor tool
    5. Via search and replace you can rename your I/O's (need to be done twice per I/O)
    6. Save the file and reopen your cell. You should now see your new names
    I hope this helps
    The difference between theory and practice is greater in practice than in theory.
  • mil3k
    21
    84
    • March 9, 2022 at 11:34 AM
    Psyril, thank you for the answer. I was sure that there must be a xml file where I could rename I/Os, but I didn't know which one and stopped before mess up something which I shouldn't. Does it work the same with Profinet I/Os? That could save me a lot of time transferring I/O names between machines.
    Quote from Johnsenfr
    CS9,
    Yes I have Master with 8 input slave card and 8 output slave card. Hardware side is set correctly.
  • Psyril
    18
    83
    • March 9, 2022 at 1:42 PM
    Quote from mil3k
    I assume it must work in a similar way, but I haven't tried it.
  • s_danieli
    8
    • June 21, 2022 at 2:12 PM
    Profinet : In SYCON, you can assign the name that you want to the bit / byte group :
  • s_danieli
    8
    Result :
  • s_danieli
    8
    • June 21, 2022 at 2:21 PM
    • Best Answer
    To gain some time, I created an Excel file with macro. It runs like this :
    1. I create the IO configuration in SRS.
    2. I export the IO configuration to CSV in SRS (It is a little bit hidden) :
    3. In my Excel file, I import the CSV data.
    4. I created a sheet where I can link my signal name and a physical link.
    5. I "just" create a macro that rewrite the signal declaration sentence in the *.dtx file of my program, like :
    <Data name="diMyDigitalInput" access="public" xsi:type="array" type="dio" size="1">
    <Value key="0" link="J206_EtherCAT\Box_1_(X20BC00G3_ST1)\%I26" />
    </Data>
    Copy paste all these declarations in the *.dtx file, and your signals will be assigned quickly in SRS. Very helpfull when you have thousands of signal to link to physical IO :smiling_face:
Similar Threads
  • Fanuc Robot to Fanuc CNC Ethernet/IP
    • Ereghi
    • August 20, 2021 at 1:22 PM
    • Fanuc Robot Forum
  • Creating EtherCAT I/O connections through WorkVisual
    • RobotProgrammer
    • June 2, 2017 at 8:38 PM
    • KUKA LBR IIWA
  • Ethernet IP connection - Invalid connection size
    • MellingTC
    • November 23, 2021 at 12:18 AM
    • Fanuc Robot Forum
  • basic i/o setup, how to for beginner
    • mflux_gamblej
    • May 14, 2021 at 3:28 AM
    • Yaskawa Motoman Robot Forum
  • R30iB DeviceNet to AB 1734-ADN
    • SkyeFire
    • May 11, 2021 at 2:19 AM
    • Fanuc Robot Forum
  • Manual Enabling Outputs
    • Jonathan PAK
    • January 19, 2021 at 2:07 PM
    • Kawasaki Robot Forum
  • SafeMove2 speed limit
    • egor
    • July 16, 2020 at 11:13 AM
    • ABB Robot Forum
  • I/O Communication problem wiith PLC
    • Dalin
    • September 27, 2018 at 9:23 PM
  • Fanuc + IPG laser profibus setup
    • Ivan
    • March 25, 2019 at 12:30 PM
    • Fanuc Robot Forum
  • EtherCAT
  • robotics suit
