Workvisual communication with S7-1200 VARIABLES
  • luis flores
  • March 7, 2022 at 10:11 PM
  • luis flores
    21
    :help:
    Hi everybody, i have a problem with the communication of variables between my KRC4 et S7-1200 siemens.
    1.- Successful project import KRC4 towards workvisual
    2.-programming and diagnosis/create connection
    *controller name:502650
    *IP address:172.31.1.147
    *version: V8.3.39.483
    3.- equal information with KRC4
    :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  • panic mode
    1,268
    13,040
    • March 8, 2022 at 1:38 PM
    it is unclear what you are doing and how to reproduce the problem.
    WorkVisual creates temporary files and folders. in your case it seem that it found the previous one. just find it and rename it, then try again.
  • luis flores
    21
    • March 8, 2022 at 2:28 PM
    I think my problem is with the name of my controller, but i am not able to change the identification
    example: 502650 windows-8M0RJ9S.
    Images
      • 109.85 kB
      • 1,920 × 1,034
      • 3
  • panic mode
    1,268
    13,040
    • March 8, 2022 at 2:35 PM
    why would you want to change that on the robot side? one is a serial number of the robot and it is assigned by KUKA. the other is windows machine name which can be changed but makes no difference anyway.
    i would look for a folder with same name on the computer running workvisual and if found rename it (by adding suffix "_old" or similar). if that fixes the problem, should be safe to delete it.
  • panic mode
    1,268
    13,040
    • March 8, 2022 at 2:37 PM
    as mentioned in READ FIRST topic, there are bunch of handy tools. one of them is a a tiny and blazing fast search engine called Everything. with this you can quickly locate files and folders if you know part of the name.
    https://www.voidtools.com/
  • luis flores
    21
    • March 8, 2022 at 2:55 PM
    Thank you very much, i made a mistake , i just changed the name of my project and not the search direction of workvisual, your help was extraordinary thank you :ola:
