Hello all,
KRC4, KSS8.6.8.
I am trying to add two extra ports into the KLI ethernet connection to be able to use RealVNC to connect to the robot.
I used to log into the robot using the Administrator user leve, then I get into Service -> network and I press the "more" button (all are translations from the robot which is in Spanish language now).
then I can get into the NAT and then I add two TCP ports and press save.
When I press the orange cross to close the windows, I get a popup message telling me that changes will be applied after resetting the robot with a "reload files".
I go into shutdown, and press Reset.
After the robot has restarted ports are not there anymore.
With all this... can you tell if I am doing something wrong?
Thank you all in advance.
