Hi all,
Could someone tell me how to run multiple instances of SRS2019? I tried every trick I could found on the Internet and non of them works.
Hi all,
In my opinion this is not possible.
What is your aim to run multiple instances?
To compare different cells, concurrent work on different cells, etc.
Hello mil3k,
can you further specify what you would like to compare?
Is it just code or 3D environments? Those are two completely different stories.
If it's juste code, you can use:
If you need to compare the 3D environment, you might need to set up a virtual machine and run a second SRS instance in there.
Ok. I understand. I was looking for comparison 3d environments.
Hello mil3k,
- the integrated comparing tool Home -> Tools -> Comparison Tool
- open both applications in SRS and compare by yourself
- open both files in any text editor tool and compare by either yourself or any comparing method provided by that tool
Does the license work across a virtual machine?
I didn't try it that way. I may try it in few weeks after finish the project and have spare time before next one kick off.
Let me know how it goes.
It can be done yes, but it is not supported nor encouraged by Stäubli.
