Hi Guys,
I finally found a used Yaskawa Motoman UP6 robot arm with XRC controller and I need help with powering it...
I have single phase residential 220/240V power and I'm considering a Rotary Phase Converter to make 3 phase power for the robot.
I've been on the phone with a few manufacturers of RPC's and I want to get some input on what they are telling me...
My UP6 robot has a payload of 6KG and uses 3 phase 220V power. kVA rating is 1.5kVA, and Horsepower is supposed to be about 1.5 as well.
I am proceeding with the knowledge that the voltage requirements are critical, and there can't be any voltage fluctuations mote than about 4%.
Looking over the websites for RPC manufacturers, the common thought is to DOUBLE the Horsepower needed to find the right size RPC.
So if I conservatively rate my robot at 2HP, I would need 4HP. I have priced a few RPC's from American Rotary and North American Rotary, and they both have 5HP converters that seem like they would be a good fit. But when I called these companies, they immediately tried to up-sell me on more expensive RPC's: Either 10HP models or Extreme-Duty models which are about double the price.
Can anyone tell me what I should be looking for? Is it the size of the Idler Motor/Generator or the Circuitry /Capacitors/Relays etc. that will determine if the unit will power the robot without any faults or damage?
Is there some way to tell the Peak current that the robot could draw - and how this affects the stability of the 3 phase converter?
Many Thanks,
Deke
