So... this is puzzling. I'm trying to calibrate a robot-carried camera for guidance, but the Integrated Vision manual only seems to have instructions for calibrating the robot to a fixed camera: make a WObj on the grid, point the camera at the grid, hit Calibrate. There's nothing about doing a multi-pose calibration to create a TCP for the camera to generate corrective motions in the right directions.
Integrated Vision -- Hand/Eye calibration for a robot-carried camera?
SkyeFire -
March 2, 2022 at 4:05 PM -
SkyFire did you ever gain any insight to this? In the past I have taught work object and then moved up to calibration position and used the posinv function to generate TCP. Agreed there should be something to generate this automatically to gain accuracy
! Teach this Point at 0,0 For Vision (At Origin Position for CalPlate, with rotation aligned to the frame)
MoveL pCal_Vision, v500, fine, tool0\WObj:=wobjCalPlate;
! ! Calculate Offset from tool0 to Wobj Origin
poseTCP:=PoseInv([pCal_Vision.trans,pCal_Vision.rot]);
! ! Set Cam Tool TCP at WorkObject Origin
tVision.tframe.trans:=poseTCP.trans;
tVision.tframe.rot:=poseTCP.rot;
No, I ended up getting reassigned, so I never got anywhere with it.
I've done vision with robot-carried cameras with non-ABB vision in the past, but the ABB Integrated Vision setup was very opaque.
