Good evening ,
I recently replaced an IRB4450S-30 2.4 RW5.11 robot
by an IRB4600-40 2.55, RW6.12 robot
the tool used is the same with TCP point in Z: -730mm fron the flange
The tool is a 10mm-12mm diameter stainless steel rod and has the function of making a hole in a sand mold.
the IRB4600 robot is having a linear trajectory variation (p1 to p2)
it is noticed that this variation occurs when the robot exerts the effort on the sand of the mold, causing the loss of the part.
the current payload of the tool is 13.8kg found via the LoadID routine.
the program modules were manually migrated to a new controller and the points were rescheduled one by one, taking advantage of the old program.
we have also tried to inform the robot's Payload Max manually (NO SUCCESSFUL).
I saw some optional ones like "Advanced Robot Motion", I don't know if it would help in this situation,
Has anyone of you been through something similar and can help?
